Posted: Wed Jul 24, 2024 1:44 am |
No idea, but I'd guess it might be a problem with the last project.
By default when you open the IDE, it opens the last project you were using.
It therefore parses the .ccspjt file for this. This has a list of the files in the
project. Possibly this has been corrupted. Now if you delete the last
ccspjt file (rename it, so it won't be found), the IDE may well then open
OK, and you can just reload the main source file. If you compile this a
new ccspft file will be made. If this works, then delete the old file. |
