bmete
Posted: Sat May 04, 2024 9:23 am |
Hello everyone,
Thank you all for your help, I finally reached the solution. This forum is truly special.
I think the problem was in the chip or pcb. Maybe the probes of the scope were corrupting the signals. I am not sure. I continued testing with the PIC18F2520 and different PCB then finally managed to communicate properly with the sensor.
Below, I am sharing a simplified version of the code that can access a total of 32 VL6180 sensors connected to 4 TCA9548s and requests distance and signal return rate information from them. Maybe it'll be useful to someone.
#include <18F2520.h>
#device ADC=10
#FUSES NOWDT
#use delay(internal=32MHz)
#use i2c(Master, sda=PIN_C4, scl=PIN_C3)
#define TCA9548_ADDRESS1 0xE0 //70 default
#define TCA9548_ADDRESS2 0xE2 //71 default
#define TCA9548_ADDRESS3 0xE4 //72 default
#define TCA9548_ADDRESS4 0xE6 //73 default
#define VL6180X_ADDRESS 0x52 // 29 default
#define VL6180X_IDENTIFICATION_MODEL_ID 0x0000
#define VL6180X_IDENTIFICATION_MODEL_REV_MAJOR 0x0001
#define VL6180X_IDENTIFICATION_MODEL_REV_MINOR 0x0002
#define VL6180X_IDENTIFICATION_MODULE_REV_MAJOR 0x0003
#define VL6180X_IDENTIFICATION_MODULE_REV_MINOR 0x0004
#define VL6180X_IDENTIFICATION_DATE 0x0006 // 16bit value
#define VL6180X_IDENTIFICATION_TIME 0x0008 // 16bit value
#define VL6180X_SYSTEM_MODE_GPIO0 0x0010
#define VL6180X_SYSTEM_MODE_GPIO1 0x0011
#define VL6180X_SYSTEM_HISTORY_CTRL 0x0012
#define VL6180X_SYSTEM_INTERRUPT_CONFIG_GPIO 0x0014
#define VL6180X_SYSTEM_INTERRUPT_CLEAR 0x0015
#define VL6180X_SYSTEM_FRESH_OUT_OF_RESET 0x0016
#define VL6180X_SYSTEM_GROUPED_PARAMETER_HOLD 0x0017
#define VL6180X_SYSRANGE_START 0x0018
#define VL6180X_SYSRANGE_THRESH_HIGH 0x0019
#define VL6180X_SYSRANGE_THRESH_LOW 0x001A
#define VL6180X_SYSRANGE_INTERMEASUREMENT_PERIOD 0x001B
#define VL6180X_SYSRANGE_MAX_CONVERGENCE_TIME 0x001C
#define VL6180X_SYSRANGE_CROSSTALK_COMPENSATION_RATE 0x001E
#define VL6180X_SYSRANGE_CROSSTALK_VALID_HEIGHT 0x0021
#define VL6180X_SYSRANGE_EARLY_CONVERGENCE_ESTIMATE 0x0022
#define VL6180X_SYSRANGE_PART_TO_PART_RANGE_OFFSET 0x0024
#define VL6180X_SYSRANGE_RANGE_IGNORE_VALID_HEIGHT 0x0025
#define VL6180X_SYSRANGE_RANGE_IGNORE_THRESHOLD 0x0026
#define VL6180X_SYSRANGE_MAX_AMBIENT_LEVEL_MULT 0x002C
#define VL6180X_SYSRANGE_RANGE_CHECK_ENABLES 0x002D
#define VL6180X_SYSRANGE_VHV_RECALIBRATE 0x002E
#define VL6180X_SYSRANGE_VHV_REPEAT_RATE 0x0031
#define VL6180X_SYSALS_START 0x0038
#define VL6180X_SYSALS_THRESH_HIGH 0x003A
#define VL6180X_SYSALS_THRESH_LOW 0x003C
#define VL6180X_SYSALS_INTERMEASUREMENT_PERIOD 0x003E
#define VL6180X_SYSALS_ANALOGUE_GAIN 0x003F
#define VL6180X_SYSALS_INTEGRATION_PERIOD 0x0040
#define VL6180X_RESULT_RANGE_STATUS 0x004D
#define VL6180X_RESULT_ALS_STATUS 0x004E
#define VL6180X_RESULT_INTERRUPT_STATUS_GPIO 0x004F
#define VL6180X_RESULT_ALS_VAL 0x0050
#define VL6180X_RESULT_HISTORY_BUFFER 0x0052
#define VL6180X_RESULT_RANGE_VAL 0x0062
#define VL6180X_RESULT_RANGE_RAW 0x0064
#define VL6180X_RESULT_RANGE_RETURN_RATE 0x0066
#define VL6180X_RESULT_RANGE_REFERENCE_RATE 0x0068
#define VL6180X_RESULT_RANGE_RETURN_SIGNAL_COUNT 0x006C
#define VL6180X_RESULT_RANGE_REFERENCE_SIGNAL_COUNT 0x0070
#define VL6180X_RESULT_RANGE_RETURN_AMB_COUNT 0x0074
#define VL6180X_RESULT_RANGE_REFERENCE_AMB_COUNT 0x0078
#define VL6180X_RESULT_RANGE_RETURN_CONV_TIME 0x007C
#define VL6180X_RESULT_RANGE_REFERENCE_CONV_TIME 0x0080
#define VL6180X_READOUT_AVERAGING_SAMPLE_PERIOD 0x010A
#define VL6180X_FIRMWARE_BOOTUP 0x0119
#define VL6180X_FIRMWARE_RESULT_SCALER 0x0120
#define VL6180X_I2C_SLAVE_DEVICE_ADDRESS 0x0212
#define VL6180X_INTERLEAVED_MODE_ENABLE 0x02A3
void enable_bus(int8 mux_address, int8 n)
int8 bus = 0;
bit_set(bus,n);
i2c_start();
i2c_write(mux_address);
i2c_write(bus);
i2c_stop();
void VL6180x_getRegister(unsigned int16 registerAddr)
i2c_start();
i2c_write(VL6180X_ADDRESS);
i2c_write((registerAddr >> 8) & 0xFF);
i2c_write(registerAddr & 0xFF);
i2c_stop();
void VL6180x_setRegister(unsigned int16 registerAddr, unsigned int8 data2)
i2c_start();
i2c_write(data2);
i2c_stop();
void VL6180x_setRegister16bit(unsigned int16 registerAddr, unsigned int16 data)
i2c_start();
unsigned int8 temp;
temp = (data >> 8) & 0xff;
i2c_write(temp);
temp = data & 0xff;
i2c_write(temp);
i2c_stop();
void VL6180x_init()
//VL6180x_getRegister(VL6180X_SYSTEM_FRESH_OUT_OF_RESET);
VL6180x_setRegister(0x0207, 0x01);
VL6180x_setRegister(0x0208, 0x01);
VL6180x_setRegister(0x0096, 0x00);
VL6180x_setRegister(0x0097, 0xfd);
VL6180x_setRegister(0x00e3, 0x00);
VL6180x_setRegister(0x00e4, 0x04);
VL6180x_setRegister(0x00e5, 0x02);
VL6180x_setRegister(0x00e6, 0x01);
VL6180x_setRegister(0x00e7, 0x03);
VL6180x_setRegister(0x00f5, 0x02);
VL6180x_setRegister(0x00d9, 0x05);
VL6180x_setRegister(0x00db, 0xce);
VL6180x_setRegister(0x00dc, 0x03);
VL6180x_setRegister(0x00dd, 0xf8);
VL6180x_setRegister(0x009f, 0x00);
VL6180x_setRegister(0x00a3, 0x3c);
VL6180x_setRegister(0x00b7, 0x00);
VL6180x_setRegister(0x00bb, 0x3c);
VL6180x_setRegister(0x00b2, 0x09);
VL6180x_setRegister(0x00ca, 0x09);
VL6180x_setRegister(0x0198, 0x01);
VL6180x_setRegister(0x01b0, 0x17);
VL6180x_setRegister(0x01ad, 0x00);
VL6180x_setRegister(0x00ff, 0x05);
VL6180x_setRegister(0x0100, 0x05);
VL6180x_setRegister(0x0199, 0x05);
VL6180x_setRegister(0x01a6, 0x1b);
VL6180x_setRegister(0x01ac, 0x3e);
VL6180x_setRegister(0x01a7, 0x1f);
VL6180x_setRegister(0x0030, 0x00);
void VL6180xDefautSettings()
//VL6180x_setRegister(VL6180X_SYSTEM_INTERRUPT_CONFIG_GPIO, (4 << 3) | (4)); // Set GPIO1 high when sample complete
VL6180x_setRegister(VL6180X_SYSTEM_MODE_GPIO1, 0x10); // Set GPIO1 high when sample complete
VL6180x_setRegister(VL6180X_READOUT_AVERAGING_SAMPLE_PERIOD, 0x30); // Set Avg sample period
VL6180x_setRegister(VL6180X_SYSALS_ANALOGUE_GAIN, 0x46); // Set the ALS gain
VL6180x_setRegister(VL6180X_SYSRANGE_VHV_REPEAT_RATE, 0xFF); // Set auto calibration period (Max = 255)/(OFF = 0)
VL6180x_setRegister(VL6180X_SYSALS_INTEGRATION_PERIOD, 0x63); // Set ALS integration time to 100ms
VL6180x_setRegister(VL6180X_SYSRANGE_VHV_RECALIBRATE, 0x01); // perform a single temperature calibration
// Optional settings from datasheet
// http://www.st.com/st-web-ui/static/active/en/resource/technical/document/application_note/DM00122600.pdf
VL6180x_setRegister(VL6180X_SYSRANGE_INTERMEASUREMENT_PERIOD, 0x09); // Set default ranging inter-measurement period to 100ms
VL6180x_setRegister(VL6180X_SYSALS_INTERMEASUREMENT_PERIOD, 0x0A); // Set default ALS inter-measurement period to 100ms
VL6180x_setRegister(VL6180X_SYSTEM_INTERRUPT_CONFIG_GPIO, 0x24); // Configures interrupt on 'New Sample Ready threshold event'
// Additional settings defaults from community
VL6180x_setRegister(VL6180X_SYSRANGE_MAX_CONVERGENCE_TIME, 0x32);
VL6180x_setRegister(VL6180X_SYSRANGE_RANGE_CHECK_ENABLES, 0x10 | 0x01);
VL6180x_setRegister16bit(VL6180X_SYSRANGE_EARLY_CONVERGENCE_ESTIMATE, 0x7B);
VL6180x_setRegister16bit(VL6180X_SYSALS_INTEGRATION_PERIOD, 0x64);
VL6180x_setRegister(VL6180X_SYSALS_ANALOGUE_GAIN, 0x40);
VL6180x_setRegister(VL6180X_FIRMWARE_RESULT_SCALER, 0x01);
void getSensorData()
i2c_start();
i2c_write((0x0018 >> 8) & 0xFF);
i2c_write(0x0018 & 0xFF);
i2c_write(0x01);
i2c_stop();
delay_ms(10);
i2c_start();
i2c_write((0x0015 >> 8) & 0xFF);
i2c_write(0x0015 & 0xFF);
i2c_write(0x07);
i2c_stop();
i2c_start();
i2c_write((0x0062 >> 8) & 0xFF);
i2c_write(0x0062 & 0xFF);
i2c_start();
i2c_write(VL6180X_ADDRESS+1);
sensor_data1 = i2c_read(0);
i2c_stop();
i2c_start();
i2c_write((0x0066 >> 8) & 0xFF);
i2c_write(0x0066 & 0xFF);
i2c_start();
sensor_data2 = i2c_read(0);
i2c_stop();
VL6180x_init();
VL6180xDefautSettings();
for (int mux = 0xE0; mux <= 0xE6; mux += 2) // for four TCA9548
for(int busNum = 0; busNum < 8; busNum++) // 8 channels
enable_bus(mux, busNum);
getSensorData();
int8 distance = sensor_data1;
int8 returnRate = sensor_data2;
//printf("Return Rate: %X --- Distance: %X \r\n", returnRate, distance);
//delay_ms(200);
PrinceNai
Posted: Sat May 04, 2024 12:57 pm |
Great, it's nice you've found the solution.
And yes, this forum is special. With a right question that shows one made at least a minimal effort to find a solution at home, someone will 100% try to help. Within a day, most likely. For us in Europe even sooner, experience shows :-) |
