Marco27293
DSPIC33EP512GP502 -- PCD v5.115 UART2 Enabling |
Posted: Fri May 03, 2024 3:01 am |
Hi, in order to use and enable uart2 on dspic33 is it sufficient:
#define UART_2_TX PIN_B11 // DsPIC UART2 TX
#define UART_2_RX PIN_B12 // DsPIC UART2 RX
#PIN_SELECT U2TX=UART_2_TX
#PIN_SELECT U2RX=UART_2_RX
#use rs232(uart2,baud=115200,PARITY=N, BITS=8, ERRORS, RECEIVE_BUFFER=100, stream=SPECTRUM)
Or I also need to set to 1 UARTEN bit 15 in register U2MODE address 0x0230 ?
Regards,
Marco |
Posted: Fri May 03, 2024 6:28 am |
Totally sufficient, _BUT_, you must have an 'enable_interrupts(GLOBAL)',
in your code, since you are relying on an interrupt to handle the receive
buffer. |
