DSPIC33EP512GP502 -- PCD v5.115 compiler
Marco27293
PostPosted: Tue Apr 30, 2024 7:48 am     Reply with quote
Hi, I have this function:
unsigned int8  THS_array[7];
int Burst_Selector_GNPs(float ArmI)
   if(THS_array[0]==0&&THS_array[1]==0&&THS_array[2]==0&&THS_array[3]==0)
      return False;
   if(THS_array[3]>0)
      if(Sum_low_freq_power(x_data)>100*THS_array[3])
         return False;
    if(THS_array[5]>0)
      if(Sum_high_freq_power(x_data)>200*THS_array[5])
         return False;
   if(THS_array[0]>0)
      if (Arm_Value(x_data, ArmI,1)<=THS_array[0]*Arm_Value(x_data, ArmI*1.5,1))
         return False;
   if(THS_array[1]>0)
      if (Arm_Value(x_data, ArmI*2,1)<=THS_array[1]*Arm_Value(x_data, ArmI*2.5,1))
         return False;
   if(THS_array[2]>0)
      if (Arm_Value(x_data, ArmI*3,1)<=THS_array[2]*Arm_Value(x_data, ArmI*3.5,1))
         return False;
    if(THS_array[6]>0)
      if ((Arm_Value(x_data, ArmI,1)+Arm_Value(x_data, ArmI*2,1)+Arm_Value(x_data, ArmI*3,1))<=THS_array[6]*10)
         return False;
   return True;
My question is : if I multiply an unsigned int8 for a number (e.g. 100*THS_array[3]) or for an unsigned int32 variable returned from another function (e.g. THS_array[0]*Arm_Value(x_data, ArmI*1.5,1)) the condition in if clause is correctly evaluated ?
I mean the multiplication result is the correct value or I get a value affected by an overflow ?
Regards,
Marco
PostPosted: Tue Apr 30, 2024 8:00 am     Reply with quote
The first will overflow, the second won't.
In the first case, '100' is an int8, and the value from THS_array is also an int8.
So int8 multiplication will be used. In the second case,if 'Arm_value' returns an
int32, then int32 arithmetic will be used.
Very much standard C. In C, the arithmetci type used is that of the 'highest'
type of value involved. Highest here is:
float
int32
int16
int8
So int32 is 'above' int16 etc. etc..
Marco27293
PostPosted: Tue Apr 30, 2024 8:06 am     Reply with quote
Isn't PCD compiler able to handle the 100*uint8 var multiplication without overflow ??
gaugeguy
PostPosted: Tue Apr 30, 2024 8:22 am     Reply with quote
If you want to do int8 x int8 with a 16 bit result there are a few ways.
standard C rules:
100L*foo
(uint16_t)100*foo
CCS function to do 8x8 multiply with 16 bit result (fastest)
_mul(100,foo)
Marco27293
PostPosted: Tue Apr 30, 2024 8:24 am     Reply with quote
I put this snippet in the code:
THS_array[0]=200; //unsigned int8
   if(THS_array[0]*20==4000)
      output_high(LED_ONBOARD);
The led turns on, so it seems no overflow... why ?
Marco27293
PostPosted: Tue Apr 30, 2024 10:09 am     Reply with quote
Please help me, I need to understand if this behaviour is PCD compiler dependant...
PostPosted: Tue Apr 30, 2024 11:43 am     Reply with quote
The point is that '100' by default in PCD, is a signed int16. PCD's default
integer type is signed int16. A 'value' without a type defaults to the
default compiler type. However _beware_. The default in PCD is always
signed. So if any value in THS_array is over 127, then you will get an
overflow.
So it is not really compiler dependant, it is 'default type' dependant.
