PIC18F14K50 - Port Pin B4 outputs High All the time.
Goto page Previous  1, 2
PostPosted: Mon Apr 29, 2024 11:01 am     Reply with quote
There were a lot of issues with the USB powered ICD units not being able
to pull up low MCLR resistors to the required programming voltage.
That is why MicroChip increased the recommended resistor value.
jeremiah
PostPosted: Mon Apr 29, 2024 12:11 pm     Reply with quote
Ttelmah wrote:
10K is a lot smaller than recommended. Minimum recommended is 22K...
10K was the recommended value back in the ICD2 days. These were able
to drive a lower resistor.
The help for the ICD-U80 recommends 50K!.
Out of curiosity, where is the doc for that on the U80. All I could find on the CCS website was the FAQ, but it lists 47k instead of 50k, so I think it is out of date.
mayur.k.vadukul
PIC18F14K50 - Debugging with Internal Oscillator
PostPosted: Tue Apr 30, 2024 1:36 am     Reply with quote
temtronic wrote:
hmm... I recall some PICs cannot use the internal oscillator when run off the Pickit3. There's got to be a 'notice' about this somewhere....
@temtronic, I am using ICD-U80 debugger.
MVadukul
PostPosted: Wed May 01, 2024 5:30 am     Reply with quote
I believe it's not the design of the programmer, rather the actual PIC that's the problem ? ICSP 'should' be the same for all PICs.
It's been years since I ran into this problem so the details are 'fuzzy'.
Page 2 of 2
