johenrod
Error when compiling to a port from a function |
Posted: Sat Apr 13, 2024 8:33 pm |
Cordial saludo, se que les puede parecer muy basico pero no encuentro la solucion.
he creado una funcion en una libreria .h y al compilar me muestra erores, dejo el codigo.(ccs)
Gracias de antemano.
Best regards, I know it may seem very basic to you but I can't find the solution.
I have created a function in a .h library and when compiling it shows me errors, I leave the code. (ccs)
Thanks in advance.
Code: | #include <16F628A.h>
//#device ADC=16
//#FUSES NOWDT //No Watch Dog Timer
//#FUSES NOBROWNOUT //No brownout reset
//#FUSES NOLVP //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
//#use delay(internal=4000000)
//#define LED PIN_A0
// #include <funciones.c>
#include <funci.h>
//#include <16F628a.h>
#FUSES NOWDT
#FUSES NOMCLR
#FUSES NOBROWNOUT
#FUSES NOLVP
#FUSES PROTECT
#use delay(internal=4MHz)
//#use RS232 (baud = 9600, bits = 8, parity = N, xmit = pin_a0, rcv = pin_a1)
//#use rs232(baud=9600,parity=N,xmit=PIN_B2,rcv=PIN_B1,stream=RF1,errors)
#define NO_ANALOGS 0 // None
#define BDIR PIN_A7
#define BC1 PIN_A6
void sonido(unsigned char registro,unsigned char valor);
#byte porta= 0x05
#byte portb= 0x06
#byte trisa= 0x85
#byte trisb= 0x86
//declaracion ariables globales
unsigned CHAR value=0;
unsigned char x=0;
// const unsigned char tone[] = {0x13, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0xfe, 0x1f, 0x00, 0x00, 0x00, 0x10, 0x01, 0x00, 0x00};
// void sound_play_song(unsigned char length, unsigned char song[]);
// void sound_register(unsigned char regnum, unsigned char value[]);
// protipos funciones
void set_mode_inactive();
void set_mode_latch();
void set_mode_write();
void write_register(char reg, char value);
SET_TRIS_A(0B00100000);
SET_TRIS_B(0B00000000);
porta=0x00;
portb=0x00;
// set_mode_inactive();
write_register(0, 223);
write_register(1, 1);
Code: | //funciones
output_low(BC1);
output_low(BDIR);
output_high(BC1);
output_high(BDIR);
output_low(BC1);
output_high(BDIR);
set_mode_latch();
PORTB = reg;
set_mode_write();
PORTB = value;
[/list]Compiling C:\Users\zolution\Desktop\code4\code3 on 13-abr-24 at 20:12
*** Error 12 "C:\Users\zolution\Desktop\code4\funci.h" Line 6(26,29): Undefined identifier BC1
*** Error 12 "C:\Users\zolution\Desktop\code4\funci.h" Line 7(26,30): Undefined identifier BDIR
*** Error 12 "C:\Users\zolution\Desktop\code4\funci.h" Line 12(27,30): Undefined identifier BC1
*** Error 12 "C:\Users\zolution\Desktop\code4\funci.h" Line 13(27,31): Undefined identifier BDIR
*** Error 12 "C:\Users\zolution\Desktop\code4\funci.h" Line 18(26,29): Undefined identifier BC1
*** Error 12 "C:\Users\zolution\Desktop\code4\funci.h" Line 19(27,31): Undefined identifier BDIR
*** Error 12 "C:\Users\zolution\Desktop\code4\funci.h" Line 25(15,20): Undefined identifier PORTB
*** Error 12 "C:\Users\zolution\Desktop\code4\funci.h" Line 28(15,20): Undefined identifier PORTB
8 Errors, 0 Warnings.
Build Failed. |
Posted: Sat Apr 13, 2024 11:50 pm |
Very simple. Order.....
The compiler reads things in the order they are declared. Now, look
where you load 'funci.h'. Then look where you declare BDIR and BC1.
So these definitions _have not yet been read_, when you load funci.h.
Result the errors (and the same for the port definitions.
Develop an order to your code:
Chip include
Fuses
Clock settings
Global defines & declarations.
Function includes or prototypes.
Main code.
Now you will note I say 'or prototypes'. In C, you can include a
prototype definition for a function, and then only include the actual
code later. Key thing is though that in every case, the declarations of
things must always be _before_ they are actually used. |
johenrod
Posted: Thu Apr 18, 2024 8:25 am |
Tiene sentido, reordene el codigo y compilo.
Muchas gracias.
It makes sense, reorder the code and compile.
Thank you so much. |
