Header file losed
almaarouf
Header file losed
PostPosted: Tue Mar 26, 2024 4:20 am     Reply with quote
I couldn't find the header file 16f18855.h. Could someone please provide it to me?
alan
PostPosted: Tue Mar 26, 2024 4:36 am     Reply with quote
Contact CCS for the file
PostPosted: Tue Mar 26, 2024 7:08 am     Reply with quote
Or just perform a re-install of the compiler. The files are added when this is
done.
However understand that if your compiler predates support for this chip,
adding the header file won't make the compiler support it.
almaarouf
PostPosted: Wed Mar 27, 2024 5:22 am     Reply with quote
done.
Can you provide me the device specifications from the "Device table editor" and the 16F18855.h header file please?
gaugeguy
PostPosted: Wed Mar 27, 2024 5:38 am     Reply with quote
No. That won't help you either. You need to purchase a newer version of the compiler.
PostPosted: Wed Mar 27, 2024 6:59 am     Reply with quote
or ,use an older PIC
What actual features do you NEED ? What is your program supposed to do ?Often an older PIC can be used,so specific information would help.
or, use a similar PIC (same family,dif RAM, might work ?)
Can you still buy the 'user configured' Compiler ? YOU chose 5 or 10 PICs,so compiler only works with them ??
newguy
PostPosted: Wed Mar 27, 2024 9:30 am     Reply with quote
What is your compiler version?
