A question about oled ssd1306 bitmap
Goto page 1, 2, 3, 4  Next
bulut_01
PostPosted: Sat Mar 09, 2024 7:17 am     Reply with quote
Good day friends, I am not very experienced about CCS, I want to show the code I created on the Oled SSD1306 screen. I am using the x.115 version of CCS and I am using the 1306 library. The code below does not compile.. image_bits How can I send the code on the screen?
static const unsigned char image_bits[] = {0x00,0x00,0x00,
0x00,0x00,0x00,0xfe,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x01,0x3e,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x00,0xc0,0x01,0x00,0x00,0x00,0x00,0x00,0x00
,0x20,0x00,0x00,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x00,0x00,0x04,0x00,0x01
,0x00,0x00,0x00,0x00,0x10,0x00,0x00,0x18,0x00,0x03,0x00,0x00,0x00,0x00,0x08,0x00,
0x00,0x20,0x00,0x0c,0x00,0x00,0x00,0x00,0x08,0x00,0x00,0x40,0x00,0x70,0x00,0x00,
0x00,0x00,0x04,0x00,0x00,0x80,0x01,0x80,0x01,0x00,0x00,0x00,0x04,0x00,0x00,0x00,
0x02,0x00,0x06,0x00,0x00,0x00,0x02,0x00,0x00,0x00,0x0c,0x00,0x18,0x00,0x00,0x00,
0x02,0x00,0x00,0x00,0x10,0x00,0xe0,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x20,0x00,
0x00,0x03,0x00,0x00,0x01,0x00,0x00,0x00,0x20,0x00,0x00,0x1c,0x00,0x00,0x01,0x00,
0x00,0x00,0x40,0x00,0x00,0xe0,0x00,0x80,0x00,0x00,0x00,0x00,0x40,0x00,0x00,0x00
,0x0f,0x80,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0x00,0xf0,0x80,0x00,0x00,0x00,0x00
,0x80,0x00,0x00,0x00,0x00,0x8f,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0xf0
,0x01,0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x80,0xfe,0x00,0x00,0x00,0x80,0x00
,0x00,0x00,0x00,0x80,0x00,0x7f,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x80,0x00,0x80,
0x7f,0x00,0x40,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0x80,0xff,0x3f,0x00,0x00,0x00,
0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x00,
0x00,0x00,0x00};
The code I sent to the screen
oled_text57(1, 10, image_bits, 1, 1);
E_Blue
PostPosted: Sat Mar 09, 2024 9:18 am     Reply with quote
What is oled_text57(????)
Where is the image size?
To send data you should call that table byte by byte.
Something similar like
unsigned int16 x;
for(x=0;x<imageByteCount;x++)
    imageSenderSub(image_bits[x]);
That's the basic idea. I don't see that in your code.
Electric Blue
PostPosted: Sat Mar 09, 2024 9:28 am     Reply with quote
A 'link' to the 'driver' you're using would help.
I'll assume the '57' in the function means a 5 pixel by 7 pixel character ?
Probably need a variable that contains the length of the array,so when you make the call, it dumps the entire array to the screen ?
E_Blue
PostPosted: Sat Mar 09, 2024 9:38 am     Reply with quote
If that array is not one image and they are several he should use a 2 dimensional array or it could get messy really easy.
Electric Blue
bulut_01
PostPosted: Sat Mar 09, 2024 10:11 am     Reply with quote
I am not very knowledgeable on this subject. Can you tell me the code to send the above code to the screen? I am using the 1306 library.
bulut_01
PostPosted: Sat Mar 09, 2024 11:16 am     Reply with quote
can you help with this
PostPosted: Sat Mar 09, 2024 11:42 am     Reply with quote
Post a 'link' to the '1306' library !
bulut_01
PostPosted: Sat Mar 09, 2024 2:27 pm     Reply with quote
PostPosted: Sat Mar 09, 2024 2:33 pm     Reply with quote
OK, didn't know it was a CCS driver, which you're NOT supposed to post.
So please delete it though one of the moderators may...
bulut_01
PostPosted: Sat Mar 09, 2024 2:36 pm     Reply with quote
Please guide me on this issue, what should I do?
PostPosted: Sat Mar 09, 2024 2:46 pm     Reply with quote
goto your post that has the ssd1306.c driver in and 'delete' the post
bulut_01
PostPosted: Sat Mar 09, 2024 2:53 pm     Reply with quote
Are you saying this should I delete the ssd1306 library and add another library?
PostPosted: Sat Mar 09, 2024 3:53 pm     Reply with quote
NO, I'm saying you need to delete your POSTING that has the SSD1306 driver in it !
You're not allowed to POST 'drivers' that CCS supplies...it's in the 'rules'.
bulut_01
PostPosted: Sat Mar 09, 2024 5:20 pm     Reply with quote
static const unsigned char wifi[] = {0x80,0x0f,0x00,0x60,0x30,0x00,0x18,0xc0,
0x00,0x84,0x0f,0x01,0x62,0x30,0x02,0x11,0x40,0x04,0x0a,0x87,0x02,0xc4,0x1f,0x01
,0xe8,0xb8,0x00,0x70,0x77,0x00,0xa0,0x2f,0x00,0xc0,0x1d
,0x00,0x80,0x0a,0x00,0x00,0x07,0x00,0x00,0x02,0x00,0x00,0x00,0x00};
//draw BMP stored in ROM
void SSD1306_ROMBMP(uint8_t x, uint8_t y, rom uint8_t *bitmap, uint8_t w, uint8_t h)
  for( uint16_t i = 0; i < h/8; i++ )
    for( uint16_t j = 0; j < (uint16_t)w * 8; j++ )
      if( bit_test(bitmap[j/8 + i*w], j % 8) == 1 )
        SSD1306_DrawPixel(x + j/8, y + i*8 + (j % 8));
        SSD1306_DrawPixel(x + j/8, y + i*8 + (j % 8), 0);
SSD1306_Begin(SSD1306_SWITCHCAPVCC, SSD1306_I2C_ADDRESS);
SSD1306_Display();
SSD1306_ClearDisplay();
SSD1306_ROMBMP(58, 17, wifi, 19, 15);
I use the ROMBMP algorithm and a ridiculous shape appears on the screen. How can I send the above static const unsigned char wifi shape to the screen correctly?
PostPosted: Sat Mar 09, 2024 6:16 pm     Reply with quote
so.. what's stored in the array called 'bitmap'
and
you still haven't deleted the CCS driver in your previous post !!!
If you don't do that soon, you'll be in trouble with the forum !!!
Page 1 of 4
