18F16Q41 - AD converter issue (solved - pin damage)
pet007
PostPosted: Sun Feb 11, 2024 11:41 am     Reply with quote
Hi, I'm a bit confused to setup ADC for the "new gen" PIC family.
So even if I define a whole ADC sample/convert procedure via 'getenv' SFR byte(+bits), I'm not able to convert ANC3 (RC3) channel. When I try to convert Internal Temp Sensor - it's working fine. Please where should be a problem ? It seems there is some issue with switching RC3 to analog input ?
#include <main.h>
  main.h:
 #device PIC18F16Q41 ADC=12
 #bit ADCON0GObit = getenv("SFR:ADCON0").0;
 #bit ADCON0FMbit = getenv("SFR:ADCON0").2;
 #bit ADCON0CSbit = getenv("SFR:ADCON0").4;
 #bit ADCON0ONbit = getenv("SFR:ADCON0").7;
 #byte ANSELA       = getenv("SFR:ANSELA");
 #byte ANSELC       = getenv("SFR:ANSELC");
 #byte ADPCH        = getenv("SFR:ADPCH");
 #byte ADACQL      = getenv("SFR:ADACQL");
 #byte ADACQH     = getenv("SFR:ADACQH");
 #byte ADRESH     = getenv("SFR:ADRESH");
 #byte ADRESL     = getenv("SFR:ADRESL");
 #byte FVRCON     = getenv("SFR:FVRCON");
u16  pwm=0, adc16=0;
void main
   set_tris_a(0b00111110);
   set_tris_b(0b00010000);
   set_tris_c(0b00111111);
   ANSELA = 0b00111000;
   ANSELC = 0b00001000;
    //set_analog_pins(PIN_C3,PIN_A4,PIN_A5);
    //setup_adc_ports(sAN4 | sAN5 | sAN19);
   FVRCON = 0b00100000;     // Temp sensor enabled
   ADCON0FMbit = 1;
   ADCON0CSbit = 1;
  // ADPCH  = 19; // ANC3 / RC3
   ADPCH  = 0b00111100; // Internal Temp Sensor - OK
   ADACQH = 0; ADACQL = 32;
   ADCON0ONbit = 1;
      ADCON0GObit = 1;
      while (ADCON0GObit);
      adc16 = (ADRESH << 8);
      adc16 += ADRESL;
      //set_adc_channel(19);
      //adc16 = read_adc();
      fprintf(PORT1,"ADC= %Lu\r",adc16); //ADRESH, ADRESL);
   } // while1
PostPosted: Sun Feb 11, 2024 12:02 pm     Reply with quote
Read note 6 on the data sheet. Section 40.7.7. That connection does not
connect to the pin it connects to the op amp. You have to configure this.
Also you should not select a channel and then immediately read. Min about
5uSec between a selection and the read.
pet007
PostPosted: Sun Feb 11, 2024 1:20 pm     Reply with quote
Hmm I don't understand - I'm selecting ADPCH = 0b00010011b (d19) - RC3/ANC3. There is any note written for this channel. It's e.g. for channel 0b10010011 (d147) - RC3(OPA1IN1+).
pet007
PostPosted: Sun Feb 11, 2024 2:29 pm     Reply with quote
I've changed MCU and it's working already - it seems this pin was damaged.......
PostPosted: Mon Feb 12, 2024 3:49 am     Reply with quote
Apologies I was thinking of another chip.
There are a couple of the chips now where the pin is shown as ANxx, but
when selected routes only to the _output_ of the internal op-amp.
Have to wonder what you actually connected to kill the ADC multiplexer
input connection here?. Pins on PIC's are not that easy to kill in general.
pet007
PostPosted: Mon Feb 12, 2024 2:25 pm     Reply with quote
Nevermind ;)
Yes, PIC's are very robust, but +13V is too much for RC3. My PCB design is a bit unlucky, when you are trying to measure divider output voltage with fuc..ng thick multimeter probe and near by is +13V input connector pin......
