DSPIC33EP128GP506 CAN BAUD RATE
georpo
PostPosted: Thu Jan 25, 2024 3:29 am     Reply with quote
I am using a DSPIC33EP128GP506 with MCP2551.
#use delay(clock=120MHz, crystal=8MHz)
How can I set the baud rate to 500K?
What are the proper values for C1CFG1 and C1CFG2?
it is a complete mess for me.
Thanks for any tips.
George.
PostPosted: Thu Jan 25, 2024 3:43 am     Reply with quote
Do what everyone else does. Use one of the online calculators.
Standard way is to use one, then sit down and do one set of calculations
yourself to be 'happy' with the values you are being given.
So (for example):
[url]
http://www.bittiming.can-wiki.info/
[/url]
Select the PIC33 as the processor type, and go from there.
georpo
PostPosted: Thu Jan 25, 2024 3:55 am     Reply with quote
Ttelmah thanks for the reply.
No matter what settings, the microchip can bus analyzer tool says "error passive" "TX ERR:128"
George.
PostPosted: Thu Jan 25, 2024 6:05 am     Reply with quote
curious was I.
googled this ... microchip can bus analyzer tool says "error passive" "TX ERR:128"
found this
https://e2e.ti.com/support/microcontrollers/c2000-microcontrollers-group/c2000/f/c2000-microcontrollers-forum/978244/launchxl-f280049c-can-bus-external-transmit-node-not-recognized
maybe will help ??
I have no idea what ERR:128 is, hopefully there's a 'list of error messages' somewhere....
georpo
PostPosted: Thu Jan 25, 2024 6:21 am     Reply with quote
it just means that there is no ACK from the other side.
I have the microchip analyzer sending data at 250k verified at the oscilloscope and on the mcp2551 data pin but my dspic never receives. on the other hand I can not set the baud rate values right.
maybe just give up and use mcp2515
George.
PostPosted: Thu Jan 25, 2024 7:33 am     Reply with quote
The MCP4551 transceiver is a 5v device. Your PIC is a 3.3v device.
Not surprising it doesn't work.
georpo
PostPosted: Thu Jan 25, 2024 7:38 am     Reply with quote
Ttelmah,
I know that but the mcp2551 data out is connected to a 5v tolerant pin of the dspic.
I have done this before, I do not think this is the problem. Do you? should I add a voltage divider?
George.
PostPosted: Thu Jan 25, 2024 7:47 am     Reply with quote
Seriously, look at MicroChip's own note on this:
[url]
https://microchip.my.site.com/s/article/CAN-transceiver-for-3-3V-microcontrollers
[/url]
georpo
PostPosted: Thu Jan 25, 2024 7:50 am     Reply with quote
I have used many many times USB-TTL adapters that are 5V directly to UART '5v tolerant" RX pins with no problem.
OK, I will just add 2 resistors and see how it goes.
George.
gaugeguy
PostPosted: Thu Jan 25, 2024 7:54 am     Reply with quote
Are you also planning to resistively divide the PIC output voltage higher?
It is a high speed bus, so should be done correctly.
Remember also that Fcan, is not the Fcpu. It is the Fp (peripheral clock), or
this *2. Depends on CANCKS.
I'm more worried about whether the output from the 3.3v device is
reliably seen as Vih on the transceiver. All too common that this is not
the case, and this would give a bus that will not correctly signal the dominant
phase.
I too have used the Texas transceivers mentioned below.
The symptoms you have are of the bus not correctly being driven...
gaugeguy
PostPosted: Thu Jan 25, 2024 7:57 am     Reply with quote
For 3.3V processors I have personally used both the TJA1042T/3 and SN65HVD230D
georpo
PostPosted: Thu Jan 25, 2024 8:00 am     Reply with quote
I just used a completely different example "EX_CAN_CCS_A_PCD.C"
compiled ok, no reception on th pic.
I will try 1k/2k resistors and order some MCP2562
George.
