gjs_rsdi
TIMER1 & TIMER3 won't interrupt |
Posted: Thu Jan 11, 2024 8:33 am |
Hi
The above timers won't interrupt in my program.
PIC18F26K22
CCS PCH C Compiler, Version 5.059, 31220
I tested on my PCB and also in MPLAB 8.92, hope somebody remember it
Timer 0 & Timer 2 interrupts have no problem
I made a new program for testing, see bellow:
Code: | /////////////////////////////////////////////////////////////////////
//TEST26K22
#include <18F26K22.h>
#device ADC=10
#FUSES WDT//Watch Dog Timer enabled; WDT period is 4ms
#FUSES WDT4//Watch Dog Timer uses 1:4 Postscale;interrupts every 16ms
#FUSES NOPBADEN//PORTB pins are configured as digital I/O on RESET
#FUSES PUT//Power Up Timer enabled
#FUSES BROWNOUT//Reset when brownout detect enabled
#FUSES BORV29//Brownout reset at 2.9V
#FUSES HSH//High speed Osc, high power 16MHz-25MHz
#FUSES PLLEN//4X HW PLL enabled
#FUSES NOIESO//Internal External Switch Over mode disabled
#FUSES NOFCMEN//Fail-safe clock monitor disabled
#FUSES NOHFOFST//High Frequency INTRC waits until stable before clocking CPU
#FUSES MCLR//Master Clear pin enabled
#FUSES STVREN//Stack full/underflow will cause reset
#FUSES NOLVP// No low voltage progming
#FUSES NOXINST//Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES NODEBUG//No Debug mode for ICD
#FUSES NOPROTECT//Code not protected from reading
#FUSES NOCPD//No EE protection
#FUSES NOWRT//Program memory not write protected
#FUSES NOWRTC//configuration registers not write protected
#FUSES NOWRTD//Data EEPROM not write protected
#use delay(clock=64MHz,crystal=16MHz)
#use rs232(baud=9600, UART1, stream=PORT1, errors)//communication with the PC
#use rs232(baud=9600, UART2, stream=PORT2, errors)
//#use I2C(MASTER, FAST=400000, I2C1, STREAM=I2CPORT)//I2C1 hardware used
#device HIGH_INTS=TRUE
#define LED PIN_B5
int LEDcounter=0;
#ZERO_RAM
#int_TIMER0
void TIMER0_isr(void)
LEDcounter++;
if(LEDcounter>=8)//524ms
LEDcounter=0;
output_toggle(LED);
#int_TIMER1
void TIMER1_isr(void)
delay_us(1);
#int_TIMER2
void TIMER2_isr(void)
delay_us(1);
#int_TIMER3
void TIMER3_isr(void)
delay_us(1);
setup_adc_ports(NO_ANALOGS);
setup_wdt(WDT_16MS);//~16 ms reset
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_16);//65.536 ms overflow
setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);//65.536 ms overflow
setup_timer_2(T2_DIV_BY_16,255,16);//512 us overflow, 8.192 ms interrupt
setup_timer_3(T3_INTERNAL|T3_DIV_BY_8);//65.536 ms overflow
setup_ccp2(CCP_CAPTURE_FE);// Configure CCP2 to capture fall
enable_interrupts(INT_TIMER3);
enable_interrupts(INT_RDA);
disable_interrupts(INT_TBE);
disable_interrupts(INT_RDA2);
disable_interrupts(INT_TBE2);
disable_interrupts(INT_CCP2);
restart_wdt();
delay_us(1);
I don't understand why. I suppose I made some mistake.
Best wishes
Joe |
Joined: 01 Jul 2010 Posts: 9160 Location: Greensville,Ontario
Posted: Thu Jan 11, 2024 9:08 am |
get rid of the WDT !
ONLY enable it when program is 100% completely tested and product is ready to go out he door.
A quick read both timer 1 and 3 are 65ms and the WDT is 16ms
so....WDT keeps resetting the program, T1 and t3 will never occour |
One thing leaps out in what you post. You have INT_RDA enabled, without
any handler for it. This is a disaster. Will cause erratic operation, and
unexpected events. Might well be the problem.
Repeat ten times, I must never enable an interrupt without a handler....
You also have high_ints enabled, but none of your interrupts are set to
be high priority. That shouldn't cause a problem but might.
As a comment, you are setting the watchdog both in fuses and using
setup_wdt. You can only setup the watchdog once. The setup_wdt line
sets up the fuses for you. I'd have expected the compiler to warn about
this. |
gjs_rsdi
Posted: Thu Jan 11, 2024 11:55 pm |
Hi Temtronic
Thank you for the answer
The project is to test only so the WDT is just there as in the program and I have restart_wdt(); in the main
I make it NOWDT in the fuses.
The fuses from the LST file:
Code: | Configuration Fuses:
Word 1: 3200 HSH PLLEN PRIMARY NOFCMEN NOIESO
Word 2: 3C06 PUT BROWNOUT BORV29 NOWDT WDT32768
Word 3: B500 CCP2C1 NOPBADEN CCP3B5 NOHFOFST TIMER3C0 CCP2B5 MCLR
Word 4: 0081 STVREN NOLVP NOXINST NODEBUG
Word 5: C00F NOPROTECT NOCPB NOCPD
Word 6: E00F NOWRT NOWRTC NOWRTB NOWRTD
Word 7: 400F NOEBTR NOEBTRB |
Hi Ttelmah
I made
Code: | disable_interrupts(INT_RDA); |
Remain there by mistake from my program
I outcommented Quote: | //#device HIGH_INTS=TRUE |
Deletet the setup_wdt in the main
But still TIMER1 and TIMER3 won't interrupt
Best wishes
Joe |
Posted: Fri Jan 12, 2024 6:14 am |
time to cut new code
New program ONLY has code for Timer1 testing
Inside the ISR, simply 'toggle led'
Don't setup serial, other timers and NO WDT code
This way the program is small, easy to see, easier to debug.
So cut new code/compile/test/report back progress. if still doesn't work, post your new program |
gjs_rsdi
Posted: Fri Jan 12, 2024 6:29 am |
Hi Temtronic
Made new program per your advice, TIMER1 still won't interrupt
//TEST26K22V1
#device ADC=10
#FUSES NOWDT//Watch Dog Timer enabled; WDT period is 4ms
//#FUSES WDT4//Watch Dog Timer uses 1:4 Postscale;interrupts every 16ms
#define LED PIN_B5
int LEDcounter=0;
#ZERO_RAM
#int_TIMER1
LEDcounter++;
LEDcounter=0;
output_toggle(LED);
delay_us(1);
Best wishes
Joe |
Posted: Fri Jan 12, 2024 6:37 am |
hmm..
maybe have main() toggle a second LED at 1Hz, to confirm the PIC is actually running at the correct speed ?
maybe use the internal oscillator as the clock source instead of the external 16MHz xtal/2 caps ??
gjs_rsdi
Posted: Fri Jan 12, 2024 6:41 am |
Hi Temtonic
The controller works because it works correct with the LED activated by TIMER0
Best wishes
Joe |
gaugeguy
Posted: Fri Jan 12, 2024 9:08 am |
I copied your code above and compiled it using version 5.061 (the closest I had to yours). The pin toggles fine.
My board has an 8MHz resonator instead of a 16MHz crystal, so 32MHz clock.
It toggles every 520ms or so.
8MHzx4 = 32MHz / 4 = 8MHz instruction /8 = 1MHz / 65536 = 15.3Hz interrupt = 65.5ms * 8 = 524ms toggle |
gjs_rsdi
Posted: Sat Jan 13, 2024 4:02 am |
Hi Gaugeguy
Thank you for the answer.
Will try it again Monday in the office
Best wishes
Joe |
Posted: Sat Jan 13, 2024 6:45 am |
There s one worrying possibility.
I too went back and looked for a compiler closer to the one being usd
here. Like you gauugeguy I found I had not lkept 5.059. Now I will keep
compilers that worked, but not keep compilers with major problems.
It is possible 5.059 was one of the ones I got rid of as 'known faulty'. ![Sad](images/smiles/icon_sad.gif) |
Posted: Sat Jan 13, 2024 7:45 am |
It'd be nice to compare the listings ! Should be real easy to spot any differences... |
Posted: Sat Jan 13, 2024 8:14 am |
There is a glaring problem.
He has left the watchdog enabled in the test program......
I was setting up to compile it and post the listing, and went to modify the
fuses (get rid of the ones controlling the oscillator since the compiler does
this), and realised he has left the watchdog enabled, so it won't work.
//TEST26K22V1
#device ADC=10
#define LED PIN_B5
int LEDcounter=0;
#ZERO_RAM
#int_TIMER1
LEDcounter++;
LEDcounter=0;
output_toggle(LED);
setup_timer_0(T0_INTERNAL|T0_DIV_16);//65.536 ms overflow
//The RTCC names are for com[atibilty with old code. Use the modern names
delay_us(1);
This compiles with 5.061, and runs correctly.
00000: GOTO 00C2
00008: MOVWF 04
0000A: MOVFF FD8,05
0000E: MOVFF FE0,06
00012: MOVLB 0
00014: MOVFF FE9,0C
00018: MOVFF FEA,07
0001C: MOVFF FE1,08
00020: MOVFF FE2,09
00024: MOVFF FD9,0A
00028: MOVFF FDA,0B
0002C: MOVFF FF3,12
00030: MOVFF FF4,13
00034: MOVFF FFA,14
00038: MOVFF FF5,15
0003C: MOVFF FF6,16
00040: MOVFF FF7,17
00044: MOVFF 00,0E
00048: MOVFF 01,0F
0004C: MOVFF 02,10
00050: MOVFF 03,11
00054: BTFSS F9D.0
00056: GOTO 0060
0005A: BTFSC F9E.0
0005C: GOTO 00AE
00060: MOVFF 0E,00
00064: MOVFF 0F,01
00068: MOVFF 10,02
0006C: MOVFF 11,03
00070: MOVFF 0C,FE9
00074: MOVFF 07,FEA
00078: BSF 07.7
0007A: MOVFF 08,FE1
0007E: MOVFF 09,FE2
00082: MOVFF 0A,FD9
00086: MOVFF 0B,FDA
0008A: MOVFF 12,FF3
0008E: MOVFF 13,FF4
00092: MOVFF 14,FFA
00096: MOVFF 15,FF5
0009A: MOVFF 16,FF6
0009E: MOVFF 17,FF7
000A2: MOVF 04,W
000A4: MOVFF 06,FE0
000A8: MOVFF 05,FD8
000AC: RETFIE 0
.................... //TEST26K22V1
.................... #include <18F26K22.h>
.................... //////////// Standard Header file for the PIC18F26K22 device ////////////////
.................... //// (C) Copyright 1996, 2020 Custom Computer Services ////
.................... //// This source code may only be used by licensed users of the CCS C ////
.................... //// compiler. This source code may only be distributed to other ////
.................... //// licensed users of the CCS C compiler. No other use, reproduction ////
.................... //// or distribution is permitted without written permission. ////
.................... //// Derivative programs created using this software in object code ////
.................... //// form are not restricted in any way. ////
.................... #device PIC18F26K22
.................... #list
.................... #device ADC=10
.................... #FUSES NOPBADEN//PORTB pins are configured as digital I/O on RESET
.................... #FUSES PUT//Power Up Timer enabled
.................... #FUSES BROWNOUT//Reset when brownout detect enabled
.................... #FUSES NOIESO//Internal External Switch Over mode disabled
.................... #FUSES NOFCMEN//Fail-safe clock monitor disabled
.................... #FUSES NOHFOFST//High Frequency INTRC waits until stable before clocking CPU
.................... #FUSES MCLR//Master Clear pin enabled
.................... #FUSES STVREN//Stack full/underflow will cause reset
.................... #FUSES NOLVP// No low voltage progming
.................... #FUSES NOXINST//Extended set extension and Indexed Addressing mode disabled (Legacy mode)
.................... #FUSES NODEBUG//No Debug mode for ICD
.................... #FUSES NOPROTECT//Code not protected from reading
.................... #FUSES NOCPD//No EE protection
.................... #FUSES NOWRT//Program memory not write protected
.................... #FUSES NOWRTC//configuration registers not write protected
.................... #FUSES NOWRTD//Data EEPROM not write protected
.................... #use delay(clock=64MHz,crystal=16MHz)
.................... #define LED PIN_B5
.................... int LEDcounter=0;
.................... #ZERO_RAM
.................... #int_TIMER1
.................... void TIMER1_isr(void)
.................... LEDcounter++;
000AE: INCF 19,F
.................... if(LEDcounter>=8)//524ms
000B0: MOVF 19,W
000B2: SUBLW 07
000B4: BC 00BC
.................... LEDcounter=0;
000B6: CLRF 19
.................... output_toggle(LED);
000B8: BCF F93.5
000BA: BTG F8A.5
000BC: BCF F9E.0
000BE: GOTO 0060
.................... void main()
000C2: CLRF FF8
000C4: BCF FD0.7
000C6: BSF 07.7
000C8: MOVLW 36
000CA: MOVWF 00
000CC: MOVLW 10
000CE: MOVWF 01
000D0: MOVLW 02
000D2: MOVWF FE9
000D4: MOVLW 00
000D6: MOVWF FEA
000D8: CLRF FEE
000DA: DECFSZ 00,F
000DC: BRA 00D8
000DE: DECFSZ 01,F
000E0: BRA 00D8
000E2: CLRF 19
000E4: MOVLB F
000E6: CLRF x38
000E8: CLRF x39
000EA: CLRF x3A
000EC: CLRF F77
000EE: CLRF F78
000F0: CLRF F79
.................... setup_timer_0(T0_INTERNAL|T0_DIV_16);//65.536 ms overflow
000F2: MOVLW 83
000F4: MOVWF FD5
.................... setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);//65.536 ms overflow
000F6: MOVLW 37
000F8: MOVWF FCD
000FA: CLRF FCC
.................... enable_interrupts(INT_TIMER1);
000FC: BSF F9D.0
.................... enable_interrupts(GLOBAL);
000FE: MOVLW C0
00100: IORWF FF2,F
.................... while(TRUE)
.................... delay_us(1);
00102: MOVLW 05
00104: MOVWF 00
00106: DECFSZ 00,F
00108: BRA 0106
0010A: BRA 0102
0010C: SLEEP
Word 2: 3C1E PUT BROWNOUT BORV19 NOWDT WDT32768
gjs_rsdi
Posted: Sun Jan 14, 2024 12:15 am |
Thank you for all the answers
Bu no, he didn't
Quote: | He has left the watchdog enabled in the test program...... |
In his code posted on Fri Jan 12, 2024 8:29 pm can see:
Code: | #FUSES NOWDT//Watch Dog Timer enabled; WDT period is 4ms
//#FUSES WDT4//Watch Dog Timer uses 1:4 Postscale;interrupts every 16ms |
In the LST of the program can see also WDT not enabled:
Best wishes
Joe |
Posted: Sun Jan 14, 2024 1:31 am |
Have to disagree.
I cut and pasted the code directly from here when it was originally posted.
The version posted had the WDT silll left enabled. The WDT4 fuse
had been remmed out, but the WDT one was still there. The reset_wdt
from the oriignal coe had been removed, so it woud not work.
Anyway I have posted the source with the watchdog disabled, and
the listing generated by the 4.061 compiler. Compile the code as I posted
it, and compae the listing. Is it the same???. This works. |
