EEPROM read anomaly
Goto page Previous  1, 2
Wilksey
PostPosted: Fri Nov 10, 2023 10:18 am     Reply with quote
Ttelmah wrote:
Remember integers in CCS by default are unsigned....
-1 = 255
Do they? I didn't realise that every other compiler defaults to signed.
Wilksey
PostPosted: Fri Nov 10, 2023 10:25 am     Reply with quote
Yes, the do while loop does the same thing though, yes I see the issue of evaluating the byte before reading it in, I could do an EEPROM read before going into the loop, but the for loop works as expected.
Thank you for your help!
gaugeguy
PostPosted: Fri Nov 10, 2023 10:34 am     Reply with quote
BYTE loaded_code[512] = {};
EEPROM_ADDRESS number_of_lines = 0x00;
do
loaded_code[number_of_lines] = read_ext_eeprom (number_of_lines);
} while (loaded_code[number_of_lines++] != 0xFF)
Wilksey
PostPosted: Fri Nov 10, 2023 10:46 am     Reply with quote
do
Yeah that doesn't work, when the EEPROM is cleared it shows 1 instruction where it should show 0, which the for loop does.
PostPosted: Fri Nov 10, 2023 10:55 am     Reply with quote
Wilksey wrote:
-1 = 255
This is one of the things that changes if you select ANSI mode.
'Every other compiler', no.
This is 'historic'. When C was first launched, the authors specifically said
that the default size and type for an integer, should be the processor's
default.
So you had things like the early PDP-8 compilers using 18bit integers that
were not signed. The PDP-11 used unsigned 16bit. Some other chips used
10bit etc. etc.. CCS when they first launched their compiler kept with
this form, and use 8bit unsigned as the default. It was only later when
ANSI C became a 'semi standard', that compilers started to default to
using signed as the 'default'. CCS has retained this on the PIC12/16/18
but then on the PIC24/30/33 because the default integer type is signed,
the PCD compiler uses this.
It results in more efficient code by default, but requires that you are
aware of this.
So 'pretty much all modern compilers', yes. But by no means 'every other'.
Wilksey
PostPosted: Fri Nov 10, 2023 10:59 am     Reply with quote
Fair point, I should have said every other compiler I have used.
Page 2 of 2
