Revo Guest
Problem transferring an array to a routine |
Posted: Sun Mar 14, 2004 9:31 am |
When I compile with PCM and PIC16f876 it work fine
But when i compile with PCH v3.168 and PIC18F252 the array is not transferred correctly
number[1] SHOULD BE 2 BUT IT IS ANOTHER VALUE
void routine(int number[5])
printf(lcd_putc," %u",number[1]);//<-------number[1] SHOULD BE 2 BUT IT IS ANOTHER VALUE
main (){
int array[5];
lcd_init();
array[1]=2;
printf(lcd_putc," %u",array[1]);
routine(array);
Can anyone help me? |
Posted: Sun Mar 14, 2004 3:43 pm |
I modified your program slightly, because I don't have a LCD on
my 18F458 demo board. I compiled it with PCH vs. 3.178, and
it worked OK. It displayed this on the terminal window:
2 2
I don't have PCH vs. 3.168, so I can't test that version.
Code: | #include <18F458.h>
#device ICD=TRUE
#use delay(clock = 4000000)
#use rs232(baud = 9600, xmit=PIN_C6, rcv = PIN_C7, ERRORS)
printf(" %u",number[1]);
main ()
int array[5];
array[1]=2;
printf(" %u",array[1]);
routine(array);
while(1); // Prevent PIC from going to Sleep
revo Guest
Posted: Sun Mar 14, 2004 4:50 pm |
I have run your code in my demo board
It displayed this on the terminal window 2 0
So I think it is a bug in the version 3.168
I will update my compiler
Thanks |
Revo Guest
Posted: Tue Mar 16, 2004 3:54 pm |
I have updated my CCS
But I have the same problem. The terminal displayed 2 0
I found a solution to resolve it.
The follow code work Ok
#include <18F458.h>
#device ICD=TRUE
void routine(int number)// <---- This is the difference before: void routine(int number[5])
main ()
int array[5];
array[1]=2;
routine(array);
Gerrit
Posted: Tue Mar 16, 2004 5:11 pm |
Revo,
Should it not be an pointer that you receive in your fuction?
void routine(char * number)//
Gerrit |
Posted: Tue Mar 16, 2004 5:19 pm |
That is strange. I have two different demo boards.
On the one I tested with your code earlier, I get "2 2".
On my other demo board, I get "2 0", just like you did.
Something weird is going on. In each case, I am using
PCH vs. 3.178. I don't have time to research it right now,
but I will, and I'll post the reason if I can find one. |
