Programming Error - UNKNOWN OPTION: parent=723518
SkeeterHawk
PostPosted: Wed Jun 07, 2023 6:56 pm     Reply with quote
Hello fellow programmers:
I am getting an unusual error when I am trying to program my PIC18F57Q84. It gives the message that I put in the remark line.
#include <RegenModule_Config.h>
//  Global variable declarations
int   Flags = 0,                                                           //  Register used to keep track of where we are in the program
      DisplayFlags = 0,                                                    //  Register to help keep the different displays "on trac"
      LED_Blink = 1,                                                       //  Register that only uses one bit to make the LED blink
      CountdownTimer = 0;                                                  //  Register that the RTC interrupt routine decrements
//signed int8
//int16
//  Other useful Regeneration Module specific functions, definitions and such
#include <RegenModule_I-O.h>                                               //  Pin assignments for the IO on this board
//#include <Flex_LCD.c>                                                      //  LCD Driver for the display
//#include <internal_eeprom.c>                                               //  Driver to be able to save above 8-bit values to the internal EEPROM
//#include <RegenModule_Displays.h>                                          //  This is the file that holds all of the displays for the system
//#include <RegenModule_Subroutines.h>                                       //  Various and assorted functions to keep things moving along
      Output_low(LED_Green);
      Output_low(LED_Red);
      Output_high(LED_Red);
      //TODO: User Code
Here is what is in the "config" file and "I/O" files respectively, which is the only include files:
#include <18F57Q84.h>
#device ADC=12
//#FUSES NOWDT                    //No Watch Dog Timer
#use delay(internal=32000000)
#pin_select SCK1IN=PIN_C3
#pin_select SDI1=PIN_C4
#pin_select SDO1=PIN_C2
#use spi (SLAVE, SPI1, MODE=0, BITS=8, STREAM=SPI_1)
//  Definitions for the local I/O pins as specific to the Regen Module application.
#define  Analog_SignalIn                  PIN_A0
#define  Aux_Analog                       PIN_A1
#define  Encoder_CS1                      PIN_A2
#define  Encoder_CS2                      PIN_A3
#define  Encoder_CS3                      PIN_A4
#define  Encoder_CS4                      PIN_A5
#define  Multiplexer_CS                   PIN_A6
#define  RTC_CS                           PIN_A7
#define  SW_Center                        PIN_B0
#define  SW_Left                          PIN_B1
#define  LocalSPI_MISO                    PIN_B2
#define  LocalSPI_CLK                     PIN_B3
#define  LocalSPI_MOSI                    PIN_B4
#define  Aux_IO_1                         PIN_B5
//#define  ICSP_Programming_Clock           PIN_B6
//#define  ICSP_Programming_Data            PIN_B7
#define  LED_Red                          PIN_C0
#define  RTC_INT                          PIN_C1
#define  PumpMasterSPI_MISO               PIN_C2
#define  PumpMasterSPI_CLK                PIN_C3
#define  PumpMasterSPI_MOSI               PIN_C4
#define  LCD_RW                           PIN_C5
#define  LCD_RS                           PIN_C6
#define  LCD_E                            PIN_C7
#define  PumpMaster_CS                    PIN_D0
#define  LED_Green                        PIN_D1
#define  LED_Blue                         PIN_D2
#define  Aux_IO_3                         PIN_D3
#define  LCD_DB4                          PIN_D4
#define  LCD_DB5                          PIN_D5
#define  LCD_DB6                          PIN_D6
#define  LCD_DB7                          PIN_D7
#define  LocalSerialOutputClock           PIN_E0
#define  LocalSerialOutputData            PIN_E1
#define  Aux_IO_2                         PIN_E2
#define  SW_Right                         PIN_F0
#define  LocalSerialOutput_HighShiftOut   PIN_F1
#define  LocalSerialOutput_ShiftOut       PIN_F2
#define  LCD_Backlight                    PIN_F3
#define  StepperOutput1                   PIN_F4
#define  StepperOutput2                   PIN_F5
#define  StepperOutput3                   PIN_F6
#define  StepperOutput4                   PIN_F7
I pulled out just about every include that wasn't being used yet, just to get rid of the possibilities. Is this something with the include file for the chip? I can't eliminate that one.
Thanks so much for the input!! I tried two different boards and got the same result, so this is definitely something with the software.
Thanks again! Very Happy
Life is too short to only write code in assembly...
PostPosted: Wed Jun 07, 2023 8:00 pm     Reply with quote
Maybe go back to the basic, simple, 'toggle an LED at 1Hz' program ??
If that works, build up from there ??
PostPosted: Wed Jun 07, 2023 11:11 pm     Reply with quote
Critical unsaid thing here _compiler version_?.
SkeeterHawk
PostPosted: Wed Jun 07, 2023 11:28 pm     Reply with quote
Great question. Sorry for not posting Embarassed
It is version 5.114.
PostPosted: Thu Jun 08, 2023 12:53 am     Reply with quote
The other thing I should have asked is 'which programmer'?. Smile
I suggest the first thing to do is try running the programmer separately.
So assuming it is a CCS programmer, run CCSLoad. Try programming from
this. You may well then get an error message that is more informative.
SkeeterHawk
PostPosted: Thu Jun 08, 2023 2:24 am     Reply with quote
That was a great suggestion! Thank you! Yes, this is a CCS ICD-U64. I will make sure that it's firmware is updated and give it a try in the morning.
Thanks again for the feedback! Very Happy
Jonathan
SkeeterHawk
PostPosted: Thu Jun 08, 2023 1:33 pm     Reply with quote
I have an update to this thread that I would like to share.
It turns out that I had to update the CCS Loader software as well as updating the firmware on the programmer. When I tried to program it using the CCS Loader as @Ttelmah suggested, it did give more information, by throwing up a TON of error windows on top of each other. I had to force it to shut down from Device Manager. Going back in, I tried to manually select the PIC18F57Q84 to get it started, and it wasn't on the list. That was my clue. I updated everything about my ICDU64, and it will now program without the error. The code still isn't acting right, but that is what "debugging" is for.
Thank you SO MUCH for your input!! I am no longer "dead in the water", woo hoo!!
PostPosted: Fri Jun 09, 2023 1:47 am     Reply with quote
Grin.
It looks like we may now know that parent=723518, is code for a particular
version of 'device not supported'....
Now for your debugging. Very Happy
Worth being aware, that some of those newer chips have complexities like
slew rate limiting on the pins, and open collector drives. Worth checking if
the chip has these, and if so, that they are correctly setup before trying
to do I/O....
