Marco27293
SPI Microsd PCB layout - pull-up resistor |
Posted: Tue Apr 04, 2023 9:05 am |
I'm actually using a microsd (SDHC, 32GB) in SPI mode (using PIC18F device).
I have 51K pull-up resistors on MOSI, MISO, CS.
I connected DAT1 and DAT2 to GND.
Is this hw configuration correct ?
I read that also DAT1 and DAT2 should be connected to supply via pull-up resistors.
If I leave them connected to GND, could I experience any problems ?
Regards,
Marco |
Posted: Wed Apr 05, 2023 3:05 am |
Directly connecting any signal to ground, that may at times output, is
a sure way 'long term', to cause problems.
When running in one bit SPI mode, DAT1` and DAT2, can both output
signals. DAT2 can be the read/wait signal, and DAT1 can be an interrupt
output. It only takes a mode where these are enabled to occur, or these
to momentarily enable on a different make of card during the wake-up,
for a direct connection to result in disaster.
The specification says:
"It is the responsibility of the host designer to connect external
pullup resistors to all data lines even if only DAT0 is to be used". |
Marco27293
Posted: Wed Apr 05, 2023 3:15 am |
Hi Ttelmah,
which specification do you refer ?
Could you give me a pdf or a link to it ?
Regards,
Marco |
Posted: Wed Apr 05, 2023 3:39 am |
www.sdcard.org
They charge for the full specification, but do a cut down version you should
be able to access. The quote is from version 3 of the full specification. |
Marco27293
Posted: Wed Apr 05, 2023 3:51 am |
Could you give me a direct link for download ?
Or at least the full name of the required doc.
I did not find it... |
Posted: Wed Apr 05, 2023 4:04 am |
No. As I said, they charge for the full specification. There are cut down
versions from other people. I think National Semi, and Samsung both
do a simplified SD card specification sheet. |
jeremiah
Posted: Wed Apr 05, 2023 9:42 am |
If he pulls section E1 from there, and looks at page 59, you have the
same message. "All hosts shall provide pull-up resistors on all data lines". |
