External RTC Inquiry ?
PostPosted: Thu Mar 11, 2004 7:14 am     Reply with quote
What's a good external RTC chips? I understand Dallas/Maxim has this components but I decided to select other brand.
BTW, I prefer I2C or SPI.
Thank u.
mvaraujo
PostPosted: Thu Mar 11, 2004 7:22 am     Reply with quote
I'm using M41T81 from ST. It's I2C. Good replacement for Dallas/Maxim.
http://www.st.com/stonline/products/families/memories/rtc/nv_t81.htm
There is a version with internal XTAL e other one without. I use the second one.
Marcus
SteveS
RTC choices
PostPosted: Thu Mar 11, 2004 8:12 am     Reply with quote
What features do you need? - square wave out, time of day alarm, backup battery switching, etc. (I'm in the middle of this same process).
- SteveS
Chas
PostPosted: Thu Mar 11, 2004 8:27 am     Reply with quote
Check out the PCF8563 from Philips. I've used it in limited numbers and it seems to work well.
mvaraujo
PostPosted: Thu Mar 11, 2004 8:42 am     Reply with quote
PCF8563 from Philips is really a good choice. Pretty cheap.
However, take care of the features you need as SteveS said.
