long v_nexa_ist_filter;
#define v_nexa_norm 60
#define v_nexa_min (25.5*(1024/v_nexa_norm))
The value calculate by the compiler is correct but if I make a compare with a long value like this:
if (v_nexa_ist_filter < v_nexa_min){
v_nexa_min_error=true;
I get and bad compare.
If I write
#define v_nexa_min 435
then all is correct.
Can anybody help me?
Re: problem with define
Posted: Wed Mar 10, 2004 11:17 am
Slammy wrote:
[i]can I make this define in a header file
If I write
Are you sure that the value being assigned is right. I'd be very suprised if it was!. You are asking the code to compare a float with a 16bit integer, and the compiler often has problems with this type of conversion.
If you code as:
#define v_nexa_min 435.0
which is what you are generating, you will get the same error.
To fix this, force the numbers to the same type. So:
#define v_nexa_min (long)(25.5*(1024/v_nexa_norm))
