Joined: 01 Oct 2003 Posts: 172 Location: Punta Gorda, Florida USA
Question about using constants isnside delay_func()
Posted: Wed Mar 10, 2004 4:52 pm
I have been trying getting around the fact that built in timing functions like delay_us, delay_(ms) or delay_cycles can only use an 8 bit unsigned variable or a constant up to 32768. I need to be able to adjust a timing sequence at runtime to a value that is larger than a byte and cannot use conditional statements such as IF or SWITCH because of their execution timing latency. One thing I thought I could do is generate various #defines and then plug them in before I execute my routines.
The basis of my question; is if you can use a constant inside these timing routines why wont the following work???
#define LongTime 23465
delay_cycles(LongTime);
It should work?? isn't the number 23465 placed in place of LongTime?
but the compiler gives me an error:
"Expression Must be a constant or simple variable"
Any help or guidance would be appreciated
cbarberis
Never Mind,, I just answered my own silly question
Posted: Wed Mar 10, 2004 5:00 pm
The fact is that delay_cycle() only uses a numerical constant or variable from 0 to 255 unlike the other functions, where if you use the #define it works OK
