Kasper
Joined: 14 Jan 2004 Posts: 88 Location: Aurora, Ontario, Canada
Interrupt on 2 different UARTS in 18F6720 locks CPU |
Posted: Mon Mar 08, 2004 1:48 pm |
I have a PIC 18F6720 hooked up with a 6MHz Crystal Oscillator and I am tryint to utilize the two hardware UARTS. I have UART1 hooked up to an RF link, and UART2 hooked up to a MAX232 Serial driver. When I have just the UART2 enabled, I can send and receive just fine. No problem.
When I have this line
Quote: |
#use rs232(baud=1000, parity=N, xmit=PIN_C6, rcv=PIN_C7, stream=PORT1, bits=8,errors)// RF Receiver
enabled in the code, the program locks up and the debugger has stopped on this very line.
Since I only need the receive function for the RF link, I have the transmit line unconnected( floating), but it being an output pin I figured it would not matter.
Does anyone have an idea what I am doing wrong here?. Why does the CPU lock up when receiving data on UART2 if UART1 is enabled???
Thanks in Advance
Kasper
MPLAB 6.4, PCWH 3.187, WinXP Pro, ICD2
#include <18F6720.H>
#include <string.h>
#fuses HS,NOPROTECT,NOWDT,NOLVP //define fuse settings
#use delay(clock=6000000,RESTART_WDT) //define system clock
#use rs232(baud=38400, parity=N, xmit=PIN_G1, rcv=PIN_G2, stream=PORT2, bits=8,errors)
#int_rda // This is the RS232 input from the rf receiver.
void RF_IN_Handler(void) {
// code to receive data....
#int_rda2 // input from the MAX232
void rs232_handler(void) {
| [/quote] |
Posted: Mon Mar 08, 2004 6:40 pm |
The data sheet says the TRIS must be set this way
for the UARTS to work. Try adding these two lines
at the beginning of main(). See if it helps.
set_tris_c(0xBF); // Set pin C6 as an output
set_tris_g(0xFD); // Set pin G1 as an output |
Kasper
Posted: Tue Mar 09, 2004 9:52 am |
I added the lines and I am afraid it made no difference :(
I have stripped my code down to this now:
#include <18F6720.H> //chip we are using
#include <string.h>
#use rs232(baud=38400, parity=N, xmit=PIN_G1, rcv=PIN_G2, stream=PORT2, bits=8, errors) //,errors)//RS232/USB/Ethernet
#use rs232(baud=1000, parity=N, rcv=PIN_C7, bits=8, errors)//,ERRORS RF Receiver
void main(void) {
enable_interrupts(INT_RDA); // RF Receiver Interrupt
enable_interrupts(INT_RDA2);// RS232/USB/Ethernet Receiver Interrupt.
enable_interrupts(GLOBAL); //enable global Interrupts
fprintf(PORT2,"\n\rSystem Initialized:\n\r"); // tells me that the port is OK
while(true){
char Received;
Received=getch();
#int_rda2 // This is the RS232 input from the PC
void rs232_handler(void){
char Received2;
Received2=getch();
fprintf(PORT2,"%c",Received2);
The code runs fine up to the point where it receives an input on PORT2, which locks the CPU and leaves the ICD cursor on the line
commenting this line out, the code works fine.
I hope someone can help here, as I am at a loss.
Thanks in advance.
Kasper
MPLAB 6.4, PCWH 3.187, WinXP Pro SP1, ICD2
/*edit: missed bracket */ |
Posted: Tue Mar 09, 2004 10:35 am |
Try the experiment of using a 'standard' baud rate (ie, 1200bps). Though you'd instictively expect the code to be able to use any acceptable rate, there may be some 'oddity' about handling exotic rates like this.
Kasper
Posted: Tue Mar 09, 2004 10:40 am |
I have tried 1200 and 38400bps and the result is the same :(
thanks for the input though ![Smile](images/smiles/icon_smile.gif) |
Neutone
Posted: Tue Mar 09, 2004 10:51 am |
Kasper wrote: | I added the lines and I am afraid it made no difference :(
#include <string.h>
void main(void) {
while(true){
char Received;
Received=getch();
char Received2;
Received2=getch();
Thanks in advance.
Kasper
Use a stream identifier for both ports.
When using putc() do it with an identifier. putc(PORT2)
When using getc() do it with an identifier. getc(PORT2)
You are trying to read a stream that has not recieved any data when another stream has recieved data. The getc() will hang when this happends. |
Kasper
Posted: Wed Mar 10, 2004 9:26 am |
you are indeed right. I used to have the stream in both #useRS232 statements, but started stripping stuff out as it was not working. The secret here seems to be the fgetc(<portname>) command.
fully working code is :
#include <string.h>
#use rs232(baud=1200, parity=N, xmit=PIN_C6, rcv=PIN_C7, stream=PORT1, bits=8, errors) //,ERRORS RF Receiver
void RF_IN_Handler(void);
void rs232_handler(void);
void main(void) {
char Received;
char Received2;
int rxflag=0;
enable_interrupts(INT_RDA2);// RS232/USB/Ethernet Receiver Interrupt. Will crash the program if left floating.
while(true){
} // end while
}// end main
char Received;
Received=fgetc(PORT1);
fprintf(PORT2,"%X",Received);
char Received2;
Received2=fgetc(PORT2);
Thanks so much for your help. ![Smile](images/smiles/icon_smile.gif) |
Posted: Wed Mar 10, 2004 10:46 am |
Brilliantly obvious 'in the end', but like most things, not untill it has been spotted!...
The key to what is happening, is that getc/putc, without a stream identifier on a stream based system, default to the 'STDIN' stream, and in the second UART handler, this is not the stream that has received the character.
