Laurent chouinard Guest
24 bits ints! |
Posted: Fri Feb 28, 2003 7:37 am |
<font face="Courier New" size=-1>I know i know, i'm demanding... But I feel like saving RAM space, and I would require 24 bit integers for data storage. Would anyone have an idea about how to achieve that?
So far, i got this method which isn't really pretty:
int32 temp;
int8 final_low, final_mid, final_high;
temp = 1294387;
final_low = make8(temp,0);
final_mid = make8(temp,1);
final_high= make8(temp,2);
//later that day...
temp = make32(0,final_high, final_mid, final_low);
Seems to me this approach is quite bulky and cpu intensive, especially since i'm already maxing out my ROM (I've got several hundred bytes free to work with).</font>
___________________________
Original Post ID: 12212 |
chas Guest
Re: 24 bits ints! |
Posted: Fri Feb 28, 2003 9:54 am |
:=<font face="Courier New" size=-1>I know i know, i'm demanding... But I feel like saving RAM space, and I would require 24 bit integers for data storage. Would anyone have an idea about how to achieve that?
:=So far, i got this method which isn't really pretty:
:=int32 temp;
:=int8 final_low, final_mid, final_high;
:=temp = 1294387;
:=final_low = make8(temp,0);
:=final_mid = make8(temp,1);
:=final_high= make8(temp,2);
:=//later that day...
:=temp = make32(0,final_high, final_mid, final_low);
:=Seems to me this approach is quite bulky and cpu intensive, especially since i'm already maxing out my ROM (I've got several hundred bytes free to work with).</font>
Maybe there's a way to use the old struct/union trick to help you out??
struct sbytes
int low_byte;
int mid_byte;
int high_byte;
int extra_byte;
union udouble
int32 int32_temp;
struct sbytes stemp;
} double_temp;
This uses only 4 bytes of ram and you can read or write as a 32 bit int and then read or write each byte individually. You could also try creating a 3 byte structure and add it to the union definition to handle your int24s and copy them in and out of the 32 bit structure??
Just an idea. (Thanks again Hans W.)
Original Post ID: 12221 |
R.J.Hamlett Guest
Re: 24 bits ints! |
Posted: Fri Feb 28, 2003 11:21 am |
:=int32 temp;
:=temp = 1294387;
You can work with 24bit variables. :-)
typedef struct {
int8 lobyte;
int8 midbyte;
int8 hibyte;
} int24word;
union int24 {
int24word word;
int8 b[3];
}my_variable;
my_variable.word=1294387l;
//You can also access the individual bytes using:
my_variable.b[0], my_variable.b[1] & my_variable.b[2]
This reserves only 24bits of storage, whereas using a int32, will reserve 32bits.
Original Post ID: 12225 |
