req: pwm in 12f675
Bomba
req: pwm in 12f675
PostPosted: Sun Mar 07, 2004 5:55 pm     Reply with quote
Is there some code to implement pwm into a 12f675?
Thanks in advance
asjad
PostPosted: Tue Mar 09, 2004 4:22 pm     Reply with quote
If the 12f675 does not have a built in CCP peripheral??
If not you could:
void main(0
int x=0;
int y=0;
Start: set_tris_d(0x00);
output_high(pin_do);
delay_ms(x);
output_low(pin_do);
delay_ms(y);
goto Start;
By changing x and y values you can change the ON and OFF time of
the signal
Hope this helps!!
Best Regards
