Is there any easy way to find out what the compiler has calculated as a constant.
ie
#define servo_idle ((max_servo_len+min_servo_len)-min_servo_len)/2
in this case i can follow the asm list and see it has it correct
00D6: MOVLW 01
00D7: MOVWF 00
00D8: DECF 04,F
00D9: MOVLW F4
00DA: MOVWF 00
lines D6 and D9 0x01F4 = 500.
thats fine, not easy,but dooable. Elsewhere tho I have a longer array of calcs. it would be nice if the symbol map or call tree or something would divulge the list of constants.
asjad
Joined: 09 Mar 2004 Posts: 52 Location: Greater Manchester - UK
watch window
Posted: Tue Mar 09, 2004 2:25 pm
I find that if you goto
Build your source code
goto view>watch (MPLAB)
scroll down until you see any variables you are intereseted
and watch their value change.
