MCUprogrammer
| dsPIC33CH128MP506 CLC [ WORKED !!!!] |
Posted: Mon Aug 15, 2022 4:59 am |
I want to use CLC peripheral with dsPIC33CH128MP506 processor. I want to control 1 output with signal from only 1 input. Incoming PULSE information is 400ns. 200ns ON. 200ns off. I want to capture this incoming pulse information and control the output as a toggle. How can I do it? _________________ Best Regards...
MCUprogrammer
_______________________________
Work Hard
Last edited by MCUprogrammer on Tue Aug 16, 2022 2:14 am; edited 2 times in total |
Posted: Mon Aug 15, 2022 5:38 am |
Start by pulling the Microchip CLC configuration tool:
[url]
https://microchipdeveloper.com/8bit:clcgui
[/url]
Have a look too at their tutorials on this:
[url]
[/url]
It sounds as if you want a standard D flip flop, with it's output inverted
and fed back to it's input, so you get an inversion on every clock. Then
just feed your input signal in as the clock.
With the configuration tool you can see what logic you need, and then
just copy this into the setup_clc lines in the compiler. |
MCUprogrammer
Posted: Mon Aug 15, 2022 6:21 am |
I did like the example below. But it didn't work.
#include <33CH128MP506.h>
#fuses NOWDT
#device NESTED_INTERRUPTS=TRUE
#use delay(clock=180MHz, crystal=20MHz)
#define A_INPUT PIN_B12
#pin_select CLCINA=A_INPUT
#define LEDOUT PIN_B14
#pin_select CLC1OUT=LEDOUT
//setup CLC1 inputs
clc1_setup_input(1, CLC_INPUT_0); //CLCINA (A_INPUT)
//setup CLC1 gates
clc1_setup_gate(1, CLC_GATE_NON_INVERTED_INPUT_1); //A_INPUT
clc1_setup_gate(2, CLC_GATE_SET);
//setup CLC1
setup_clc1(CLC_ENABLED | CLC_MODE_AND | CLC_OUTPUT | CLC_OUTPUT_INVERTED);
MCUprogrammer
Work Hard |
MCUprogrammer
Posted: Tue Aug 16, 2022 2:13 am |
ok it worked. No need to flip flops. I'm approximating the incoming pulse in 100ns. If the input is 1, the output is 1. If the input is 0, the output is also 0. _________________ Best Regards...
MCUprogrammer
Work Hard |
Posted: Tue Aug 16, 2022 5:58 am |
| You said you wanted the output to 'toggle'. That implies a flip-flop..... |
MCUprogrammer
Posted: Tue Aug 16, 2022 10:15 am |
That's exactly what I said. Output 1 when input is 1, output 0 when input is 0. _________________ Best Regards...
MCUprogrammer
Work Hard |
gaugeguy
Posted: Tue Aug 16, 2022 11:19 am |
| That sounds like a buffer |
Posted: Tue Aug 16, 2022 11:36 am |
| Yes, that is just a simple buffer gate, not a toggle. |
MCUprogrammer
Posted: Wed Aug 17, 2022 3:23 am |
I am getting this error while installing the program. What would be the reason
TEST.hex
12:20:54 Assigning chip: DSPIC33CH128MP506
12:20:54 Loaded: DSPIC33CH128MP506
12:20:55 Assigning chip: DSPIC33CH128MP506
12:20:55 Loaded: DSPIC33CH128MP506
12:20:57 Target Vdd = 3.25
12:20:59 Target Vdd = 3.25
12:21:00 Target Vdd = 3.25
12:21:01 Target Vdd = 3.25
12:21:03 Target Vdd = 3.25
12:21:04 Target Vdd = 3.25
12:21:06 Target Vdd = 3.25
12:21:07 Target Vdd = 3.25
12:21:09 Target Vdd = 3.25
12:21:10 Target Vdd = 3.25
12:21:13 Target Vdd = 3.25
12:21:13 Assigning chip: DSPIC33CH128MP506
12:21:13 Loaded: DSPIC33CH128MP506
12:21:13 Setting Vpp=0
12:21:15 Assigning chip: DSPIC33CH128MP506
12:21:15 Loaded: DSPIC33CH128MP506
12:21:15 Write FILE -> CHIP
12:21:16 Setting Vpp=0
MCUprogrammer
Work Hard |
Posted: Wed Aug 17, 2022 3:39 am |
To have any hope at all of helping, we need to know what programmer
you are using, and what software to drive it.
Display looks like something like possibly MPLAB, rather than CCS.
Nothing there looks like an error. |
MCUprogrammer
Posted: Wed Aug 17, 2022 4:00 am |
CCS C 5.109
ICD U80 _________________ Best Regards...
MCUprogrammer
Work Hard |
Posted: Wed Aug 17, 2022 4:15 am |
So, you are using the 'Program' option from inside the IDE?.
Try using CCSload directly instead.
CCSload itsefl is what is being called by this option, but run directly it is
more likely to tell you the error. It also has diagnostics allowing you to
test what is happening.
I still do not see an error being reported.
The U80 is very prone to problems if the cable or connection is not perfect.
I use cables half the length of the supplied ones, and these reduce problems
massively. |
MCUprogrammer
Posted: Wed Aug 17, 2022 5:01 am |
I used CCSLOAD directly. fail again
14:00:46 Param: +DEBUGLOG
14:00:47 Attempting to connect
14:00:51 Scanning file: C:\Users\ertan\Desktop\PIC_GPIO_SPEED_TEST\DSPIC33CH128MP506 CLC\CLC TEST.hex
14:00:51 Assigning chip: DSPIC33CH128MP506
14:00:51 Loaded: DSPIC33CH128MP506
14:00:53 Assigning chip: DSPIC33CH128MP506
14:00:53 Loaded: DSPIC33CH128MP506
14:00:53 Write FILE -> CHIP
14:00:54 Setting Vpp=0 |
MCUprogrammer
Work Hard |
Posted: Wed Aug 17, 2022 6:30 am |
So, what do the diagnostic selections say?.
Firmware up to date.
Do all the pins test correctly.
The point is that CCSLoad allows you to test things. |
