I have written a test program on INT0 but I am not able to test it out on the hardware yet due to unavalibility. Can someone be kind enough to tell me whether the code will works.
A push button is connected to Pin B0 which when pushed will caused the chip to go into SLEEP mode. A second push on the pushbutton will bring the chip active and reset via reset_cpu().
// global flag to send processor into sleep mode
short sleep_mode;
// external interrupt when button pushed and released
#INT_EXT
void ext_isr()
if(button_pressed_once) // if button action and was not
// pressed
button_pressed_once=FALSE; //to activate the next button pressed
// which is to reset the thing
sleep();
button_pressed_once=TRUE; // the button is now up
reset_cpu();
ext_int_edge(H_TO_L); // init interrupt triggering for button press
enable_interrupts(INT_EXT);// turn on interrupts
static short button_pressed_once=TRUE;
jds-pic
Re: Using Hardware Interrupt (INT0)
Posted: Mon Mar 08, 2004 9:09 pm
ericzuki wrote:
#INT_EXT
void ext_isr()
// pressed
sleep();
reset_cpu();
it may just be me but i don't like the idea of going to sleep inside an interrupt handler function. i believe that this is asking for debugging troubles and it's just not good programming practice. why not just set a flag in #int_ext and test it in main()? keep your inerrupt handlers simple.
