How to Wake-Up with WDT
pilar
PostPosted: Tue Jun 14, 2022 10:59 am     Reply with quote
I'm using a PIC18LF4520 and I'm using it with CCS 4.074, I want to use a low power state and for that I send it to sleep and I want to wake it up with the WDT but it seems that it's not working, the pic doesn't wake up, can someone tell me how to solve this ?
#include <18F4520.h>
#fuses HS,WDT128,NOPROTECT,NOLVP
main()   {
   switch ( restart_cause() )   {
      case WDT_TIMEOUT:      {
         printf("\r\nRestarted processor because of watchdog timeout!\r\n");
      case NORMAL_POWER_UP:      {
         printf("\r\nNormal power up!\r\n");
   setup_wdt(WDT_ON);
   restart_wdt();
   SLEEP();
   while(TRUE)   {
PostPosted: Tue Jun 14, 2022 11:25 am     Reply with quote
If the 18F4520 is sleeping, a WDT timeout will cause the PIC to wake up
from sleep and continue running code after that point. If the PIC is sleeping,
the WDT will not cause a reset.
This is in the PIC datasheet, in section:
3.5.2 EXIT BY WDT TIME-OUT
pilar
PostPosted: Tue Jun 14, 2022 11:52 am     Reply with quote
Yes, I read it, but it is not clear to me, what would I have to modify in this code to get what I need, that the pic goes to sleep and that the WDT wakes it up?
PrinceNai
PostPosted: Tue Jun 14, 2022 12:15 pm     Reply with quote
Maybe this will do what you want:
main()   {
      case RESET_INSTRUCTION:      {
   setup_wdt(WDT_ON);
   restart_wdt();
   SLEEP();
   reset_cpu();
   while(TRUE)   {
Mind that the code as it is will never reach while(true) loop, so it will basically just keep resetting the CPU. I suppose you want it to do something when the processor wakes up :-)
PostPosted: Tue Jun 14, 2022 12:17 pm     Reply with quote
Try something like this:
#fuses HS,WDT512,NOPROTECT,NOLVP, PUT
#use delay(clock=20M)
printf("Start\n\r");
restart_wdt();
sleep();
delay_cycles(1);
printf("Wake-up from sleep occurred\n\r");
   restart_wdt();
PrinceNai
PostPosted: Tue Jun 14, 2022 12:30 pm     Reply with quote
Or if you want something done after wake-up, something like this:
#define Working 1
#define Sleeping 2
int8 Go_To_Sleep = Working;
main()   {
   setup_wdt(WDT_ON);
   restart_wdt();
   while(true){
      switch (Go_To_Sleep)   {
         case Sleeping:     {
            printf("\r\nSleeping!\r\n");
            sleep();
         case Working:      {
            printf("\r\n!Working!\r\n");
            Go_To_Sleep = Sleeping;
Restart WDT as needed..
pilar
PostPosted: Tue Jun 14, 2022 5:11 pm     Reply with quote
Smile Thanks everyone, i got what i needed
PrinceNai
PostPosted: Tue Jun 14, 2022 7:25 pm     Reply with quote
Nice to hear. For the posterity it would be cool if you posted which answer helped you. So that someone with a similar question can find a solution Very Happy
Regards,
Samo
pilar
PostPosted: Wed Jun 22, 2022 3:30 pm     Reply with quote
Thank you PrinceNai, your code worked for me Very Happy
#define Working 1
#define Sleeping 2
main()   {
   setup_wdt(WDT_ON);
   restart_wdt();
   while(true){
         case Sleeping:     {
            sleep();
         case Working:      {
