rhaguiuda
Joined: 05 Sep 2007 Posts: 46 Location: Londrina - Brazil
Split Float to 2 INT |
Posted: Wed Sep 05, 2007 8:33 am |
Hi
What is the easiest way to split a 32 bit float in 2 int?
Exemple:
Float: 124.56
Int1: 124 (integer part of the float)
Int2: 56 (fractional part of the float)
Exemple 2:
Float: 1423.5431
Int1: 1423
Int2: 5431
Any help is welcome.
Thanks a lot! |
Posted: Wed Sep 05, 2007 8:51 am |
You would have no way of distinguishing 1234.0056, from 1234.5600 with what you show. You need to decide on a scale factor to be used (for the second example, *10000), and keep this the same, so in the first case, the result would be 5600, not 56.
Remember you need to use int16 values to hold anything beyond 255. Also the one holding the part in front of the DP, will need to be signed.
You need to include 'math.h', then use:
int16 fract;
signed int16 intval;
float val;
float intpart;
val=1234.5678
fract=(modf(val,&intpart) * 10000);
intval=intpart;
The last line automatically casts the integer part (stored as a float), into an integer.
rhaguiuda
Posted: Thu Sep 27, 2007 10:53 am |
Thanks a lot for reply Ttelmah!  |
vasiliok
Joined: 17 May 2011 Posts: 19 Location: Kaunas, Lithuania
Posted: Wed Mar 30, 2022 11:21 pm |
Hello!
Could you please tell me what I'm doing wrong?
float intpart;
unsigned int16 T1_trupmn;
signed int16 T1_sveikoji;
float DS_T1;
DS_T1 = -10.96; // Temperature
T1_trupmn=(modf(DS_T1,&intpart) * 10000);
T1_sveikoji=intpart;
fprintf (PC, "integer = %Ld\n\r", T1_sveikoji);
fprintf (PC, "fractional = %Lu\n\r", T1_trupmn);
DS_T1 = -0.01; // Temperature
Got results:
for -10.96:
integer = -10
fractional = 55936
for -0.01:
integer = 0
fractional = 65436 |
Posted: Thu Mar 31, 2022 12:19 am |
Read the CCS manual:
Quote: | modf( )
The modf() function breaks the argument value into integral and
fractional parts, each of which has the same sign as the argument.
It stores the integral part as a float in the object integral.
See page 347. |
Posted: Thu Mar 31, 2022 12:32 am |
and (of course), it writes a _float_ value to the variable whose address is
passed. Writing a 4 byte float into a 2 byte integer, is not only going to give
screwy results, it'll probably result in the next variable in memory being
corrupted. |
vasiliok
Posted: Thu Mar 31, 2022 1:11 am |
Thanks for reply Ttelmah and PCM programmer!
You forced me to read and think!
Corrected my code. Getting integer part and 1 digit of fractional part correctly now.
float intpart;
signed int8 T1_trupmn;
signed int8 T1_sveikoji;
float trpmn;
float DS_T1;
DS_T1 = -1.29;
trpmn=(modf(DS_T1,&intpart) * 10);
T1_sveikoji=(signed int8)intpart;
T1_trupmn = abs((signed int8)trpmn);
fprintf (PC, "integer = %d\n\r", T1_sveikoji);
fprintf (PC, "fractional = %d\n\r", T1_trupmn);
Got:
integer = -1
fractional = 2
Tried different negative values and it works fine!
Values are for DS18b20 temperatures so it will be in -40...+60 range.
Need two integer bytes of temperature to send packet via RS485.
It is all ok now! |
Posted: Thu Mar 31, 2022 4:25 am |
Good.
Have fun with the rest of the project. |
Joined: 01 Jul 2010 Posts: 9444 Location: Greensville,Ontario
Posted: Thu Mar 31, 2022 6:01 am |
OK, now that it's done and works,..
..I have to ask why not just send the two 'raw data' bytes to the PC instead of having the PIC convert to float, then convert to 2 'split' bytes ?
PICs are slow with floats and fancy 'math',also a lot of memory used for the code.
Just curious.
Posted: Thu Mar 31, 2022 7:51 am |
Why does it ever get to/involve a float at all?.
The chip returns a binary 'count' of temperature in steps, usually of 0.0625C.
It really should be being handled all the way as integer, Perhaps simply in
counts, or multiplied to give an integer in hundredths of a degree.
Zero need to ever use floats at all.... |
newguy
Posted: Thu Mar 31, 2022 8:22 am |
The most difficult repeating task I've ever faced is trying to wean fresh graduates off of the "float" mentality. The most extreme example I've ever seen was a co-op student that predated my time at an organization who wrote a completely custom 16 bit "float" type so that the system would display values to 4 decimal places (xxx.xxxx).
What they completely missed was the best case overall system resolution. If they had bothered to take the maximum analog output from the sensor and divide that by the 12 bit A/D (4096 steps) it fed, the absolute best case resolution we could hope to achieve was 0.4 units, or xxx.x.
The only times I've ever needed to use floats was in situations where I needed to compute a logarithm or when I needed to determine the distance between two locations denoted by latitude/longitude. Luckily with both those situations, I didn't need to actually compute things quickly - once per second or so was fast enough. |
Posted: Thu Mar 31, 2022 10:28 am |
Absolutely.
The 'float mentality' is unfortunately very much ingrained. However the
more experienced users here (and with any other small chips), instead
use things like scaled integers to do the job, and the code is smaller, faster
and more reliable.
I have got a couple of applications that use floats, for sixth order polynomial
linearisation, and for a logarithmic sensor. However like you I look at the
code size, storage size, and speed involved. |
djsb
Posted: Fri Mar 21, 2025 9:04 am |
I have to admit I have this "float mentality" and I would like to change this.
Could someone please give me a simple example of how to use integers instead of floating point numbers when using an MCP9700 sensor.
Despite reading through the forum, I STILL haven't got the memo. Thanks. |
Posted: Fri Mar 21, 2025 12:05 pm |
google 'scaled integers mcp9700' ccs code is out there 'somewhere'...
I now as I copied it years ago,though where on this PC is anyone's guess ! |
Posted: Sat Mar 22, 2025 2:37 am |
As a comment, the MCP9700, does not even warrant scaled integers.
It is not capable of giving better than 1C resolution. +/-2% at best....
Obviously the values it actually gives from the ADC would depend on the
ADC Vref. It is a very simple output 0.5v at 0V and 10mV/degree. So if
(for instance), you are running with 5v ref, then:
Vref=5v. 10bit ADC gives 0.00488 per step (read up on why this is /1024
not /1023 for the PIC ADC). So 2.048 steps per degree. So 100C =
205 steps. Needs division by 2.05 from steps = *.4878.
So take Vin from the ADC into a signed int32. Subtract 103 (0.5v).
Then multiply by 31, and divide by 64. 31/64 is 0.4843. Division by binary
values is the fastest, while multiplication is also quick. Result is integer
degrees and will be as close given the accuracy of the sensor as it is capable
of giving. |
