I'm working on a project that uses the PIC16C765 and I am unable to detect the processor with the ICD-S40. I am able to read the device ID which is 0B82. Have I anything change in the chip edit?
Any help would be appreciated.
Cheers,
andy
hillcraft
Joined: 22 Sep 2003 Posts: 101 Location: Cape Town (South africa)
16F765 ICD
Posted: Sat Mar 06, 2004 1:20 pm
I am sure that the ICD is only meant to be used on the specific Flash devices that support In Circuit Debugging. Like the 16F876, 18F458 etc.
I don't think that the ICD can be used as a fully comprehensive device programmer.
Anoher point: the 16C765 is a OTP device. If you are running a 16C765-JW then the device must be erased via a UV EEPROM eraser.
