IAM using pcw ver3.28 and i am attempting to use funcion pointers so that
i can get the address of different functions. The help files tell me i can't use function pointers but i've being told that it can and it does compile the declaration of a function pointer. Standard ansi c will compile the following:
void dummy(void);
main()
void (*ptrfunction)(); //declaration of function pointer
ptrfunction = dummy; //assigment
void dummy(void)
int i;
i++;
However with the picc compiler it will compile the declaration unlike previous compilers but wont compile the assignment. It will give me the error IMPROPER USE OF FUNCTION IDENTIFIER. If i change the assignment to
ptrfunction = dummy();
It will compile it perfectly, but it doesnt work.
Where am i going wrong or what is the deal with function pointers in PICC.
dyeatman
3.157 The compiler can now generate COFF debug files
3.158 A hang problem (since 3.157) is fixed
3.158 A new format for the help file (.CHM) has been released
3.160 Pointers to functions are now supported <*****************
3.160 Examples updated to use more modern chips
3.160 PCW IDE improvments incorporated
3.160 Some COFF debug file problems are resolved
3.162 More PCW IDE improvments incorporated
Re: FUNCTION POINTERS
Posted: Thu Mar 04, 2004 9:48 am
void dummy(void);
main()
void dummy(void)
int i;
i++;
Limited 'pointer to function' support exists _from V3.160 onwards_. You say version 3.28. If this is 3.028, then the ability doesn't yet exist.
There is a list on the CCS website, that gives the changes between versions.
