a Guest
| Can i use this line in CCS C compiler. |
Posted: Tue Mar 02, 2004 6:53 am |
unsigned char Key_Schedule[16][48];
This line is must use in DES Algorithm.
Compiler warning
How i use it? Or i Can't. |
Felix Althaus
Joined: 09 Sep 2003 Posts: 67 Location: Winterthur, Switzerland
Posted: Tue Mar 02, 2004 7:04 am |
Hello
I think it should be possible if yo use a PIC which has 16*48 = 768 bytes of ROM empty for the array.
What warning do you get?
Felix |
| a |
Posted: Tue Mar 02, 2004 7:07 am |
Compiler warning.
Not enough RAM for all variables. |
mpfj
I don't see why not. Are you claiming that we get an error message ? If so, what ?
Of course, your choice of PIC may be of influence !! You're creating an array that contains 768 bytes of data, and (a) not all PICs have that much RAM and (b) I don't think all PICs support large tables. |
| Re: Can i use this line in CCS C compiler. |
Posted: Tue Mar 02, 2004 11:07 am |
| a wrote: | Can i use this line in CCS C compiler.
Compiler warning
Only in an 18 family chip.
On all the other chips, the maximum array size is limited by the RAM banksize available.
Posted: Tue Mar 02, 2004 1:31 pm |
Sorry for my fault post. because i rectify this line from
to
unsigned char Key_Schedule[128];
I'am so Sorry For my fault.
Compiler Show :
Error[45] C:\Micropro\SourceCode_Picc\DES.c 7 : Subscript out of range
And how i solve my problem. Please tell me.
Below is all my sourcecode that i test.
#include "C:\Micropro\SourceCode_Picc\DES.h"
#include<string.h>
#define DES_ENCRYPT 1
#define DES_DNCRYPT 0
unsigned char Key_Schedule[16][48]; <--This line i am fault post; Sorry
//static const unsigned char LS[17]={1,1,2,2,2,2,2,2,1,2,2,2,2,2,2,1};
//unsigned char PC1[56]={57,49,41,33,25,17,9,1,58,50,42,34,26,18,10,2,59,51,43,35,27,19,11,3,60,52,44,36,63,55,47,39,31,23,15,7,62,54,46,38,30,22,14,6,61,53,45,37,29,21,13,5,28,20,12,4};
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_counters(RTCC_INTERNAL,RTCC_DIV_1);
setup_timer_1(T1_DISABLED);
| a |
Posted: Tue Mar 02, 2004 1:59 pm |
Now i change from Pic16f877 to Pic18f458 in my sourcecode everything is OK. But if i want use it int Pic16f877. Can i do it . Because i will write this sourcecode in SmartCard (Silvercard -->Pic16f87+24LC64). Thank you for all post . Please tell me if u have any idea. Or Anyone have sourcecode Des Algorithm or other Encryption/Decryption in C language.
I will use Silvercard (Pic16f877+24LC64). |
