dexta64
printat function |
Posted: Wed Dec 01, 2021 7:45 am |
Those who want the function can develop more complex.
But I will simply share.
#define printat(x,y,_str,nmr) do{ \
lcd_gotoxy(x,y); \
printf(lcd_putc,_str,nmr); \
}while(0);
or
#define printat(x,y,_str,nmr,nmr1) do{ \
lcd_gotoxy(x,y); \
printf(lcd_putc,_str,nmr,nmr1); \
}while(0);
Here's the usage
int8 month=12;
printat(1,1,"MONTH: %02d",month);
or
int16 year=2021;
printat(1,1,"YEAR: %lu",year);
or this is how it is defined
lcd_gotoxy(x,y); \
}while(0);
int16 year=2021;
int8 month=12;
printat(1,1,"Date: %lu/%02d",year,month);
jeremiah
Posted: Thu Dec 02, 2021 10:12 am |
you can also use variant macro arguments:
#define printat(x,y,_str,...) do{ \
lcd_gotoxy(x,y); \
printf(lcd_putc,_str,__VA_ARGS__); \
}while(0);
Also you can also use multiple statement syntax if you like:
#define printat(x,y,_str,...) \
(lcd_gotoxy(x,y), printf(lcd_putc,_str,__VA_ARGS__))
dexta64
Posted: Tue Dec 07, 2021 1:34 am |
jeremiah thank you so much. It had puzzled me for days.
"__VA_ARGS__"
is that the magic command? I shared well.
typedef struct
uint8_t day;
uint8_t month;
uint8_t year;
uint8_t dow;
uint8_t hour;
uint8_t min;
uint8_t sec;
}t_time;
t_time date;
printat(1,1,"TEST");
printat(2,1,"T:%02d/%02d/%02d-%02d:%02d",date.day,date.month,date.year,date.hour,date.min);
it works perfectly. |
dexta64
Posted: Tue Dec 07, 2021 3:26 am |
other I have defined and working
The lcd_puts command is like this in the lcd driver.
void lcd_puts(char * str)
while (*str != '\0') //\0 will scan the inside of lcdtxt until you see this
//statement.
lcd_putc(*str);
str++;
my definitions
//command i get string from rom
//My goal is to save ram space.
#define printst(x,y,_str) \
(lcd_gotoxy(x,y), strcpy(lcdtxt,_str), lcd_puts(lcdtxt)) //lcdtxt be very careful here.
//This way it uses a lot of ram. Also the Rom area.
#define printstr(x,y,_str,...) \
(lcd_gotoxy(x,y), sprintf(lcdtxt,_str,__VA_ARGS__), lcd_puts(lcdtxt)) //lcdtxt be very careful here.
#device PASS_STRINGS=IN_RAM without using this definition.
reads the definition directly from the Rom.
unsigned char lcdtxt[16]; //regular program variable that I defined once. I throw my writings in it.
const char menuprgstatus[2][12]={
"ON STAND-BY",
"WORKING "};
//on my lcd drive x=row, y=column
printst(1,1,menuprgstatus[0]);
printst(2,1,menuprgstatus[1]);
dexta64
Posted: Tue Dec 07, 2021 3:32 am |
Ttelmah thank you so much. |
