In many examples we can use for example a #Define Pin_to_Use PIN_D1.
This is used when compiler generate the code.
However I have seen an example of change the PIN in runtime like this:
int16 pin_to_use;
pin_to_use=PIN_B0;
output_low(pin_to_use);
pin_to_use=PIN_B1;
But this does not work in my case so I wonder what can go wrong with this type of code in CCS ? It compiles OK but the I/O address is wrong not point to the address defined in header file for the MCU.
Are there other ways to alter the PIN in an output_high(PIN_xx) at runtime maybe ?
I use compiler 5.076 and MCU is a 30F5011.
PeWa
Re: Change PIN at Runtime
Posted: Sat Nov 27, 2021 8:43 am
int16 pin_to_use;
pin_to_use=PIN_B0;
pin_to_use=PIN_B1;
Edited, the variable address is OK. I can change a static LED but it seems that when I change to variable the output / input functions take some more time to compute. Is that the case ??
Posted: Fri Dec 03, 2021 2:29 am
You can also use the get_env for the PORT and LAT register addresses.
Then build a struct as you like with a default set of values.
Then just write those values to PORT/LAT registers on start up.
You end up configuring an entire register with a single write.
I'd have to go look at an old example to see how much ASM results.... but it should be pretty thin. _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D
