chingB
| I2C Inquiry for my application |
Posted: Mon Mar 01, 2004 11:27 pm |
I have a setup which uses two PICs -- one is a master with an external I2C memory. The other PIC is a slave which sends 16bytes data to the master. Once the master received the 16bytes data it will then be stored to an external memory.
My question: How can I utilize the #int_ssp on my application/project?
Thank u. |
Posted: Tue Mar 02, 2004 12:22 pm |
chingB,
| Quote: | | My question: How can I utilize the #int_ssp on my application/project? |
Yes, you can if you use a pic device with hardware i2C implemented. I could be even greater if you use for the master, a device that has master i2c on board.
Regards,
Marcus |
chingB
Posted: Tue Mar 02, 2004 5:23 pm |
| Anonymous wrote: | chingB,
Regards,
Marcus |
Hi Marcus!
Do you have a sample snippets on this using the #int_ssp? I'll be glad if you can share it.
Thank u. |
mvaraujo
Posted: Mon Mar 08, 2004 12:43 pm |
HI ChingB,
Unfortunately, I don't have any code that uses this #int. I using I2c comm without any isr.
Marcus |
