Bug in string printing ... 3v186
mpfj
PostPosted: Tue Mar 02, 2004 5:36 am     Reply with quote
Device = PIC18F8720
I've just reported the following bug to CCS ...
void write_char(char c) {
   // dummy statement to ensure routine is used
   c++;
   int8 i = 0;
   write_char(text[i]);
Problem
When passing a string to a function taking a char as its parameter (i.e. your virtual "print string" implementation), the TBLPTRH register is not updated correctly.
Although the register is initialised okay, when the index value is incremented after calling the lookup code, only the least significant byte is incremented, thus limiting the lookup to the first 256 bytes.
0210:  CLRF   0B       <- 0x0B holds the index MSB
0212:  MOVFF  09,0A    <- 0x0A holds the index LSB
0216:  MOVFF  0B,FF7   <- index MSB placed in TBLPTRH register
021A:  MOVF   0A,W     <- index LSB placed in WREG
021C:  CALL   0004     <- call to table lookup code
0220:  IORLW  00
0222:  BTFSC  FD8.2
0224:  GOTO   0234
0228:  INCF   0A,F     <- index LSB incremented, but not the MSB !!!
022A:  MOVWF  0B       <- index MSB now corrupted
022C:  GOTO   01E0     <- call to "print character" routine
0230:  GOTO   0216     <- loop
As you can see, on line 0x228, the index LSB is incremented, but the index MSB is not updated with any carry overflow.
You will also notice that the index MSB register is used to pass the value to the "print character" routine, thus corrupting the index value !!
These bugs are coming thick and fast !!!
Mark
PostPosted: Tue Mar 02, 2004 11:20 am     Reply with quote
I normally use PCM for most projects, so I don't watch PCH problems
that much. But currently, we are doing a project using PCH 3.178.
I notice you're finding a lot of Table Read bugs. Do you think these
are just in the most recent versions, or were they in earlier versions ?
Is PCH 3.178 safe ? We will be building a few hundred units.
If there is some doubt about it, I'm going to have to test it for
all these bugs.
PostPosted: Tue Mar 02, 2004 11:41 am     Reply with quote
all these bugs.
Historically, PCH, had a lot of problems in the early 3.xxx versions. By about 3.14x, 90% had been fixed, and code that had previously worked on the 16 chips would now work without too much work on the 18 chips. There have since been a number of changes to the development enviroment, and the development tools, and a whole new 'crop' of bugs seem suddenly to have arisen in areas that were working before. I partially suspect that CCS, are trying to get some of the things that still had problems 'fixed', and are creating new faults. Though the 18 family, should not have the limits on array sizes etc., that applied to the 16 family, in some areas they still seemed to remain in place (with odd problems appearing in larger structures). I think this is why they are 'fiddling' here.
It is perhaps indicative that they still have 3.148 showing (which was one of the first versions that worked pretty well for me).
If you don't mind the older enviroment, I'd stay with this version.
Chas
PostPosted: Tue Mar 02, 2004 11:56 am     Reply with quote
All variables in your example are 8 bits (int8 an char). Thus you can not have more than 256 entries in your tables. Have you tried changing your index or other variable to a long to see if this changes the generated assembly code?
mpfj
PostPosted: Wed Mar 03, 2004 3:38 am     Reply with quote
True, all my variables are 8bit, but I'm not really using these as the index value. I'm legitimately relying on the compiler to sort out the index offsets of my string array.
I *should* be able to define the following ...
char text[2][200] = {...};
... which creates 2 x 200 character strings. Both dimensions are 8bit, but obviously the compiler needs to *automatically* convert this into a 16bit offset, since the whole array is > 256 bytes.
