GiG
Oscillator and timer interference |
Posted: Wed Nov 03, 2021 4:48 am |
Hello friends, since I just started CCS, I have a series of problems with it.
I just wrote a program in which I used Timer0 and Timer1.
And I called the commands related to the timer and got the numbers according to the formula calculations of the timer.
But because I also need to use an oscillator, when I add this command to the code:
Code: | setup_oscillator (OSC_8MHZ | OSC_PLL_on);
| everything becomes faster and the previous calculations of the timer formula are no longer correct.
and when i remove this command from the code every thing is good.
I wanted to see if anyone knows why?
What i used in main
Setup_timer_0(RTCC_INTERNAL|RTCC_DIV_8);
setup_timer_1(T1_internal | T1_DIV_BY_8);
//setup_oscillator(OSC_8MHZ | OSC_PLL_on); // <===the problem is here
// for adc use
setup_vref(VREF_ADC_1v024);
setup_adc_ports(sAN7|sAN9 , VREF_FVR);
setup_adc(ADC_CLOCK_DIV_64);
setup_adc_ports(sAN7|sAN9);
Joined: 01 Jul 2010 Posts: 9225 Location: Greensville,Ontario
Posted: Wed Nov 03, 2021 5:36 am |
You need to tell us which PIC you're using and the compiler version !
Also your original program clock configuration. |
GiG
Posted: Wed Nov 03, 2021 5:43 am |
#include <16f1939.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,PLL_SW,NOMCLR,NOBROWNOUT,PUT
#device ADC=10
#use delay(internal=8000000)
#INCLUDE <math.h>
this is config |
Posted: Wed Nov 03, 2021 6:10 am |
It's clear that you want the PIC to run at 8 MHz. But then you're turning
on the PLL which makes it run 4x faster, at 32 MHz. If you don't want
that, then don't turn on the PLL. |
GiG
Posted: Wed Nov 03, 2021 7:10 am |
PCM programmer wrote: | It's clear that you want the PIC to run at 8 MHz. But then you're turning
i don't understand why ? when im using this command
i put the osc on 8 mhz |
Posted: Wed Nov 03, 2021 7:26 am |
The point is what you do in your code, overrides what you do in the setup.
The code line:
says to run the oscillator at 8MHz, _and enable the PLL to give 32MHz_.
You are overriding the OSC_8MHz setup by then enabling the PLL.
The 8MHz clock does not use the PLL..... |
GiG
Posted: Wed Nov 03, 2021 9:33 am |
Ttelmah wrote: | The point is what you do in your code, overrides what you do in the setup.
The code line:
So you mean when i calculate timer0 formula
I should use 32MHZ instead of 8mhz in calculating?!
And if i do it right
Is there anything wrong with the timer calculations? |
Posted: Wed Nov 03, 2021 10:02 am |
I mean if you want to run at 8MHz, then the line is simply:
setup_oscillator (OSC_8MHZ);
To run at 8MHz, you don't enable the PLL. |
GiG
Posted: Wed Nov 03, 2021 2:25 pm |
Ttelmah wrote: | I mean if you want to run at 8MHz, then the line is simply:
Thank you
But ok PLL puts the clock on 32Mhz.
What about that 8mhz before it ?!
For what we have that command before PLL command? |
gaugeguy
Posted: Wed Nov 03, 2021 2:37 pm |
If you use #use delay(internal=8000000) then there is no reason to use the setup_oscillator command unless you are trying to change it to something different. |
Posted: Thu Nov 04, 2021 12:48 am |
'setup_oscillator' is the command.
The values passed to it are the 'parameters', saying what you want to set
it 'to'.
Now, the PLL can be fed from either the 8MHz oscillator, or any external
frequency using the LP, XT, HS RX or EC oscillators.
So there are two parts to the setting. The first saying 'what clock source',
and the second saying whether to enable the PLL or not.
If you enable the PLL with a legitimate clock source, then the output
frequency fed to the CPU is 4* the clock frequency.
So your command was saying 'select the 8MHz clock, then multiply this by
four'. |
gaugeguy
Posted: Thu Nov 04, 2021 6:25 am |
This is also clear if you look at the data sheet. The PLL can only accept a 4MHz - 8MHz input and generate a 16MHz - 32MHz output. When used with the internal oscillator, only the 8MHz can be connected to the PLL, producing a 32MHz clock for the processor. |
