HaveAchat
MMCSD problem |
Posted: Sun Oct 24, 2021 4:25 pm |
I am trying to implement an SD card and feel I am the only person in the world to fail this simple task!
I am using a CCS PIC18F67J60 demonstration PCB and a SanDisk 8GB SD card.
I am using standard libraries. I have moved the files and changed their names so I can try and debug my issue.
I have modified the mmcsd file to add the loop to switch the card to SD mode and some print commands to see what is happening.
Serial listing
ex_mmcsd.c
mmcsd Initilisation
Set to SD Mode
r1 after go idle cmd 0x01
Send op cond
time out r1 after send op cond 0x01
Could not init the MMC/SD!!!!
Any assistance would be appreciated.
//// ex_mmcsd.c ////
//// Similar to ex_extee.c, an example that demonstrates ////
//// writing and reading to an MMC/SD card. ////
//// Select either the ICD or your own RS232-to-PC connection ////
//// for the text I/O. ////
//// (C) Copyright 2007,2018 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS ////
//// C compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, ////
//// reproduction or distribution is permitted without written ////
//// permission. Derivative programs created using this software ////
//// in object code form are not restricted in any way. ////
//These settings are for the CCS PICEEC development kit which contains
//an MMC/SD connector.
#include <18F67J60.h>
//#use delay(clock=25M)
#use delay(crystal=25000000)
//!#use rs232(icd) //Text through the ICD
#use rs232(baud=9600, UART1, errors) //Text through the UART
#include <stdlib.h> // for atoi32
#define LCD_RS_PIN PIN_F1
#define LCD_RW_PIN PIN_F2
#define LCD_ENABLE_PIN PIN_F3
#define LCD_DATA4 PIN_F4
#define LCD_DATA5 PIN_F5
#define LCD_DATA6 PIN_F6
#define LCD_DATA7 PIN_F7
#include <lcd.c>
//meda library, a compatable media library is required for FAT.
#use fast_io(c)
#define MMCSD_PIN_SCL PIN_C3 //o
#define MMCSD_PIN_SDI PIN_C4 //i
#define MMCSD_PIN_SDO PIN_C5 //o
#define MMCSD_PIN_SELECT PIN_C2 //o
#include <mmcsd-play.c>
#include <input-play.c>
BYTE value, cmd;
int32 address;
printf(lcd_putc,"\fnex_mmcsd.c\n");
printf("\r\n\nex_mmcsd.c\r\n\n");
if (mmcsd_init())
printf("Could not init the MMC/SD!!!!\r\n");
while(TRUE);
do {
do {
printf("\r\nRead or Write: ");
cmd=getc();
cmd=toupper(cmd);
putc(cmd);
} while ( (cmd!='R') && (cmd!='W') );
printf("\n\rLocation: ");
address = gethex();
address = (address<<8)+gethex();
if(cmd=='R')
mmcsd_read_byte(address, &value);
printf("\r\nValue: %X\r\n", value);
if(cmd=='W') {
printf("\r\nNew value: ");
value = gethex();
printf("\n\r");
mmcsd_write_byte(address, value);
mmcsd_flush_buffer();
} while (TRUE);
printf("mmcsd Initilisation\r\n");
mmcsd_deselect();
delay_ms(15);
/* fill send data with all ones - 80 bits long to */
/* establish SPI link with SD card this fulfills the */
/* 74 clock cycle requirement... */
printf("Set to SD Mode\r\n");
for(i = 0; i < 10; i++)
MMCSD_SPI_XFER(0xFF);
/* begin initialization */
i = 0;
do
delay_ms(1);
mmcsd_select();
r1=mmcsd_go_idle_state();
mmcsd_deselect();
i++;
if(i == 0xFF)
mmcsd_deselect();
printf("time out r1 after go idle cmd 0x%X\r\n",r1);
return r1;
} while(!bit_test(r1, 0));
printf("r1 after go idle cmd 0x%X\r\n",r1);
printf("Send op cond \r\n");
i = 0;
do
delay_ms(1);
mmcsd_select();
r1=mmcsd_send_op_cond();
mmcsd_deselect();
i++;
if(i == 0xFF)
mmcsd_deselect();
printf("time out r1 after send op cond 0x%X\r\n",r1);
return r1;
} while(r1 & MMCSD_IDLE);
printf("r1 after send op cond 0x%X\r\n",r1);
Posted: Mon Oct 25, 2021 12:54 am |
Go to the code library.
There are a number of issues with the standard supplied libraries. In the
library there are the fixes for these. Since your card is over 4GB, at least
two of these fixes are _needed_ to get it working.
Biggest 'common problem' with SD, is the need for the large capacitor
adjacent to the card. This is absolutely essential, since these cards draw
huge spikes on the power rails doing certain operations. Also, have you
got the required pull up resistors on the lines?.
Typically something like a low ESR 22uF close to the card, and pull ups on
CS, Data_OUT - SDI(to the PIC), DAT1, and DAT2.
The extra pull-ups on DAT1 & DAT2, are needed to ensure how the card
wakes up. The SDI one is in the specifications to improve the speed
of the rising edge on that signal. The CS is needed because this line can
otherwise float before the PIC wakes up. The card itself is meant to have
a 50K pull up on this line internally. Better to be safe though.... Use
10KR for all the resistors.
As another comment, are you sure the library you are using supports
using fast_io?. Most of the supplied libraries do not. |
HaveAchat
Posted: Mon Oct 25, 2021 11:49 pm |
Thank you Ttelmah,
I am embarrassed to ask but where is the "code library"?
I have the pullups but no Cap so I will add that over the next few days. |
HaveAchat
Posted: Mon Oct 25, 2021 11:51 pm |
NO!!!!! don't tell me!!!!! its in my face!!!!!!
What can I say..... |
Posted: Tue Oct 26, 2021 10:18 am |
Hidden in plain sight!.. |
