Also as both a general, and 'specific' comment to what is being done,
#defines must _only_ be used for the commands for which they are
listed.
So the define 'H_TO_L', says
"// Constants used in EXT_INT_EDGE() are:".
This define cannot be used in the ENABLE/DISABLE interrupts command.
If you look for the defines for these commands, you see:
