Irregular counting in the timer0,Timer1 PIC
GiG
PostPosted: Fri Sep 03, 2021 11:50 pm     Reply with quote
Hi, I do not know whether to open the topic correctly or not.
I had a question about PIC and CCS, I'm a little familiar with it
I wanted to make a 1 second pause with the timer.
I wanted help with the code I wrote.
The problem is Timers that sometimes the timer works but it counts irregularly or it counts and stops somewhere.
Notes:
-The connections to the timer sockets are constantly going up and down.
-The frequency is 8 MHz.
-PIC16F1939
The rest of the functions that are related to the display on a specific segment worked well. I tried counting with simple functions and it had no problems in counting.
#include <16f1939.h>
#FUSES PUT
#FUSES NOBROWNOUT
#fuses HS,NOWDT,NOPROTECT,NOLVP ,PLL_SW,NOMCLR
#device ADC=10
#use delay(internal=8000000)
#INT_TIMER0
//#INT_TIMER2
#use FIXED_IO( A_outputs=PIN_A7,PIN_A6,PIN_A5,PIN_A4,PIN_A3,PIN_A2,PIN_A1,PIN_A0 )
#use FIXED_IO( B_outputs=PIN_B1,PIN_B0 )
#use FIXED_IO( C_outputs=PIN_C7,PIN_C6,PIN_C5,PIN_C4,PIN_C3,PIN_C2,PIN_C1,PIN_C0 )
#use FIXED_IO( D_outputs=PIN_D7,PIN_D6,PIN_D5,PIN_D4,PIN_D3,PIN_D2,PIN_D1,PIN_D0 )
#use FIXED_IO( E_outputs=PIN_E1,PIN_E0 )
int16 speedb,timex,time_hour ,time_mint,time_sec,dg_hour,yk_hour,dg_mint,yk_mint,h_timer,m_timer,on_timer,second,hour,minute,counter;
int16 hg_dama,sg_dama,dg_dama,yk_dama,seg_buf,chbuf1,chbuf2,chbuf3,h,t;
#define up_led   PIN_A0
#define onoff_led   PIN_A1
#define dwn_led   PIN_A2
#define light_led   PIN_A3
//-----------------------------7 segment
#define cm10   PIN_A4
#define cm9   PIN_A5
#define cm8   PIN_E0
#define cm7   PIN_E1
#define cm5   PIN_A6
#define cm6   PIN_A7
#define cm4   PIN_C0
#define cm3   PIN_C1
#define cm2   PIN_C2
#define cm1   PIN_C3
#define d_seg   PIN_C4
#define c_seg   PIN_C5
#define b_seg   PIN_C6
#define a_seg   PIN_C7
#define dot_seg   PIN_D0
#define g_seg   PIN_D1
#define f_seg   PIN_D2
#define e_seg   PIN_D3
//----------------------------------------- c phase
#define sens1   PIN_B1
#define sens2   PIN_B2
#define buzzer   PIN_B1
#define ir_sensor   PIN_B4
//------------------------------------------toch key
#define up_key   PIN_B5
#define onoff_key   PIN_B6
#define dwn_key   PIN_B7
#define light_key   PIN_E3
//-------------------------------------------output
#define speed4   PIN_B0
#define speed3   PIN_D7
#define speed2   PIN_D6
#define speed1   PIN_D5
#define light   PIN_D4
void show_seg(void){
       switch (seg_buf){
            Case 0 :
                output_high(a_seg);
                output_high(b_seg);
                output_high(c_seg);
                output_high(d_seg);
                output_high(e_seg);
                output_high(f_seg);
                output_low(g_seg);
            Case 1:
                output_low(a_seg);
                output_high(b_seg);
                output_high(c_seg);
                output_low(d_seg);
                output_low(e_seg);
                output_low(f_seg);
                output_low(g_seg);
            Case 2:
                output_high(a_seg);
                output_high(b_seg);
                output_low(c_seg);
               output_high( d_seg);
               output_high( e_seg);
                output_low(f_seg);
               output_high( g_seg);
            Case 3:
                output_high( a_seg);
                output_high( b_seg);
                 output_high(c_seg);
                output_low(e_seg);
                output_low(f_seg);
             Case 4:
               output_low( a_seg);
               output_high( c_seg);
                output_low(d_seg);
                output_low(e_seg);
               output_high( f_seg);
              Case 5:
                output_low(b_seg);
                output_low(e_seg);
              Case 6:
                 output_high(a_seg);
                output_low(b_seg);
                 output_high(c_seg);
                 output_high(e_seg);
                 output_high(f_seg);
                 output_high(g_seg);
              Case 7:
                output_high(a_seg);
                output_high(b_seg);
                output_high(c_seg);
                output_low(d_seg);
                output_low(e_seg);
                output_low(f_seg);
                output_low(g_seg);
              Case 8:
                output_high(a_seg);
               output_high( b_seg );
                output_high(c_seg );
                output_high(d_seg);
                output_high(e_seg);
               output_high( f_seg );
                output_high(g_seg );
              Case 9:
                output_high(c_seg);
                output_high(d_seg);
                output_low( e_seg);
void split_display(void)
chbuf1=chbuf3/10;
chbuf2=chbuf1*10;
chbuf2=chbuf3-chbuf2;
void main(){
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_16);
set_timer0(131);
while (1)
if (get_timer0()==0)
set_timer0(250);
counter++;
if (counter>=20){
minute++;
counter=0;
if (minute>=59){
hour++;
minute=0;
if (hour>=59){
 second=minute=hour=0;
    output_high(cm1);
    output_high(cm2);
    output_high(cm3);
    output_high(cm4);
    output_high(cm5);
    output_high(cm6);
    output_high(cm7);
    output_high(cm8);
    output_high(cm9);
    output_high(cm10);
        chbuf3=hour;
        split_display();
        dg_hour=chbuf1;
        yk_hour=chbuf2;
        seg_buf=dg_hour;
       show_seg();
     output_low( cm5);
     Delay_us (10);
     output_high( cm5 );
       output_low(a_seg);
       output_low(b_seg);
       output_low(c_seg);
       output_low(d_seg);
       output_low(e_seg);
       output_low(f_seg);
       output_low(g_seg);
       seg_buf=yk_hour;
       show_seg();
      output_low( cm6);
      Delay_us (10);
      output_high( cm6 );
        chbuf3=minute;
        split_display();
        dg_mint=chbuf1;
        yk_mint=chbuf2;
        seg_buf=dg_mint;
       show_seg();
      output_low( cm7);
      Delay_us (10);//50
      output_high( cm7 );
       output_low(a_seg);
       output_low(b_seg);
       output_low(c_seg);
       output_low(d_seg);
       output_low(e_seg);
       output_low(f_seg);
       output_low(g_seg);
       seg_buf= yk_mint;
       show_seg();
      output_low( cm8);
      Delay_us (10);//50
      output_high( cm8 );
       output_low(a_seg);
       output_low(b_seg);
       output_low(c_seg);
       output_low(d_seg);
       output_low(e_seg);
       output_low(f_seg);
       output_low(g_seg);
clear_interrupt(INT_TIMER0);
Only the part related to the timer has a problem. Is there another way to write it?
PostPosted: Sat Sep 04, 2021 12:50 am     Reply with quote
while (1)
Why do you think you will see this specific count of 0 ?
Your timer is counting at a rate of 125 KHz, which means it's clocked
every 8 usec. Your while() loop takes much longer than 8 usec to execute.
During that time, Timer0 will pass through many, many counts. The odds
of it being at a count of 0 when you poll it are very low.
#INT_TIMER0
//#INT_TIMER2
These two lines don't do anything. You have no interrupt routines.
You don't enable interrupts. Delete those two lines.
#device ADC=10
If you're specifying the internal oscillator in the #use delay() statement,
then you don't need the HS or PLL_SW fuses.
PostPosted: Sat Sep 04, 2021 5:14 am     Reply with quote
Had a quick look at your code....
Have a look/read of this thread...
http://www.ccsinfo.com/forum/viewtopic.php?t=26177
it's a SW based Real Time Clock in the Code Library.
You can probably modify and use it.
I did several times, before using the DS3231 RTC came out.
Jay
GiG
PostPosted: Sat Sep 04, 2021 11:29 pm     Reply with quote
PCM programmer wrote:
while (1)
#INT_TIMER0
//#INT_TIMER2
#device ADC=10
Thanks for the tips.
So I used that interrupt instead and the problem is solved.
