set_tris_a(0b0000111);
setup_adc(ADC_CLOCK_DIV_32);
setup_adc_ports(sAN0|sAN1|sAN2);
set_adc_channel(0);// Battery Voltage Sense
set_adc_channel(2);// mains Voltage Sense
adc_value=read_adc();
batt_volt=adc_value/20.449;
mns_volt=adc_value/20.449;
//batt_volt=adc_value*(5/1023);//20.449;
if (batt_volt >= 13.8 )//<=14.0)// && batt_volt <= 1.0 )
delay_ms(3000);
output_high(LED);
if (mns_volt <= 1.0 )//<=3.0)
delay_ms(3000);
output_high(RELAY);
output_low(RELAY);
delay_ms(3000);
output_low(LED);
_________________ heroswap1981
Posted: Sat Aug 21, 2021 3:31 am
You have to work like this:
delay_us(10); //The channel has to be selected long enough
//for the signal to acquire -> Tacq. Check the data sheet for what this
//needs to be (9.55uSec min on your chip).
adc_value=read_adc(); //This now reads the battery voltage
delay_us(10);
adc_value=read_adc(); //This now reads the main voltage sense.
Sequence is always select channel, wait for signal to acquire, then sample
this.
