Looping for with variable
vtrx
PostPosted: Wed Jul 28, 2021 4:59 am     Reply with quote
How should I declare the variable in this looping?
var x=10;
int8 c;
for(c=0;c < x;c++){do something;}
PostPosted: Wed Jul 28, 2021 6:33 am     Reply with quote
Any way you want....
x here can be char, int, int8, int16, float, int32, etc. etc. etc..
If it is anything but an int, there will be a variable conversion carried out for
every comparison, which costs space and time, but it will still work.
PostPosted: Wed Jul 28, 2021 6:34 am     Reply with quote
As the comparison ranges from 0 to something positive...
NO negative numbers involved.
First, I'd declare 'C' as a CHAR ( 0 to 255).
2nd, declare 'X' as CHAR as well (again 0 t0 255 ).
CCS C makes 'char' same as unsigned int8, so less typing.
vtrx
PostPosted: Wed Jul 28, 2021 6:48 am     Reply with quote
int8 chip;
chip = 4;
void sendData(unsigned int16 data)
int8 c;
  output_low(CS);
  spi_xfer(max7912,data);
   for(c=0;c < chip;c++){spi_xfer(max7912,REG_NO_OP);}
  output_high(CS);
The code above doesn't work, but if I put a fixed value, it works.
int8 c;
  output_low(CS);
   for(c=0;c < 4;c++){spi_xfer(max7912,REG_NO_OP);}
  output_high(CS);
PostPosted: Wed Jul 28, 2021 8:09 am     Reply with quote
You probably don't actually ever get to the line where chip is set to 4 before
you call the function....
PostPosted: Sun Aug 01, 2021 9:16 am     Reply with quote
Now you don't say what processor you are using. On a DsPIC,
a 'char is a signed int8. Can't hold things over 127. Generally learn to
be explicit on variable sizes:
    unsigned int8 posi, offset;
    //don't use 'chars' for numeric valus their size chages
    for(posi=0;posi < 8;posi++)
         for(offset=248; offset>=128; offset-=8)
             MAX7219_write(8-posi,scroll_buf[offset + posi],chip);
Your problem is almost certainly that you are not using a variable that
can actually 'hold' the values you are trying to use. If your char is a
signed int8, the maths will wrap, and the result will be completely wrong.
Also, if you are counting in eights, just count in eights. No point in
fiddling with separate counts and offsets.
