lilayta
Compiler error |
Posted: Mon Mar 01, 2004 5:49 am |
Iam making a division between two integers numbers , and Iam using the structure div_t. The problem is , the compiler always give me the same error :" expecting a variable"
The goal of the program is to select the hundred, tens of units of a decimal number, to put onto 3 displays of 7 segments.
The code of the visualization is not represented here.
I don't know if faults me some instruccion or if something in my code is wrong. Here it is my code:
#include <16f877.h>
#include <string.h>
#include <stdlib.h>
main()
div_t x;
x=div(grados,100);
centenas = x.quot;
num1 = x.rem;
x=div(num1,10);
decenas = x.quot;
unidades=x.rem;
Al
Posted: Mon Mar 01, 2004 6:33 am |
Are you sure this is where your problem lies? It compiles fine for me. I don't know what you have declared your variables as, but I declred them as ints.
int grados, centenas, num1, decenas, unidades;
What complier are you using? _________________ Alan Murray |
