converting hexadecimal to decimal value
raman00084@gmail.com
PostPosted: Sat Jul 24, 2021 1:55 am     Reply with quote
char gps_buf[]={"GPGGA,000044.262,,,,,0,0,,,M,,M,,*4E"};
in the array the last 2 characters is the check sum value ( 4E)
HOW CAN I CONVERT THE LAST 2 CHARACTERS TO DECIMAL VALUE
FOR EXAMPLE
CHAR CHECK_SUM[3]={0}
CHECK_SUM[0]='4';
CHECK_SUM[1]='E';
HOW TO CONVERT THIS TO DECIMAL VALUE THAT IS 78
KINDLY HELP.
PostPosted: Sat Jul 24, 2021 4:39 am     Reply with quote
quick reply..
CCS supplies the function ATOI().
If you open the manual, it's listed and the example program 'input.c' shows how to use it.
jay
PostPosted: Sat Jul 24, 2021 10:45 am     Reply with quote
Though atoi is supplied, it is quite a complex way of doing the conversion.
Easier to just use a simple convert and multiply on the characters. So:
int htodec(char c)
    if(c >= '0' && c<= '9')
       return c-'0';
    if(c >= 'A' && c <= 'F')
       return c-55;
    if (c >= 'a' && c <= 'f')
       return c-87;
    return 0; //Impossible character
//then for the locations of the '4E':
val=htodec(gps_buf[34])*16+htodec(gps_buf[35]);
Should give the value in decimal.
I think I've counted the locations correctly (do check...).
This is faster and smaller than using atoi
PostPosted: Sun Jul 25, 2021 5:13 am     Reply with quote
Hey Mr. T....
Using Notepad+, I get 35, and 36 as the locations.
BUT...that's really 34 and 35 as we have to start at ZERO for arrays.
In QB45 you could use either '0' or '1' as the starting cell.
Jay
PostPosted: Sun Jul 25, 2021 6:57 am     Reply with quote
Cor, I counted right!... Very Happy
I was just counting characters on a laptop.
