Posted: Tue Jul 06, 2021 7:33 am |
Slave addresses are required to be even. Cannot be odd. |
L.T.
Posted: Tue Jul 06, 2021 11:14 pm |
Ttelmah wrote: | Slave addresses are required to be even. Cannot be odd. |
Hi Ttelmah,
What did you mean? I dont understand. |
Posted: Tue Jul 06, 2021 11:40 pm |
You said
Quote: |
But if I change it to 0x13(00010011)
Slave addresses can _only_ be even numbers. They cannot be odd numbers.
A slave set with an address of 0x12, responds to address bytes of both 0x12,
and 0x13. The actual 'slave address', is the upper 7 bits of the byte sent. |
L.T.
Posted: Wed Jul 07, 2021 12:18 am |
and 0x13. The actual 'slave address;, is the upper 7 bits of the byte sent. |
Hii Ttelmah,
I didnt want to say to change the slave address as 0x13. When the slave address is 0x12 and I want to send data from the master and send 0x12 as address+r/w from the master, I can send data from the master and read from the slave. 0x12 is 00010010. When I send 0x12 from the master, isn't it the slave address information from the 7th bit to the 1st bit (0001001), and the r/w bit if the 0th bit (0) is? Isn't it necessary to give a write command (1) before sending data from the master? When I send 0x13 as address+r/w from the master, the write command must be given, the last bit is 1. Why can I send data at 0x12 and not 0x13? |
L.T.
Posted: Wed Jul 07, 2021 2:00 am |
Hi PCM programmer,
I did some changes in my code as the link you sent. I can send data from master and slave read correctly. But when master sent to slave request data order, master didnt read correctly. Slave sent 4, master read 0x26. Why?
When I debugged in the slave code, I've seen it never go inside if(state==0x80).
#include <16F18346.H>
#fuses XT,NOWDT,NOPROTECT,NOLVP,PUT
#define Slave_Read 0x12
#define Slave_Write 0x13
/* Delay for 4 mhz crystal */
#use delay(clock = 24MHz)
/* Setup I2C */
#pin_select SCL1OUT = PIN_C3
#pin_select SCL1IN = PIN_C3
#pin_select SDA1OUT = PIN_C6
#pin_select SDA1IN = PIN_C6
#use I2C(MASTER, I2C1, SLOW)
main()
int8 OKU;
setup_oscillator(OSC_HFINTRC_24MHZ,OSC_CLK_DIV_BY_16);
set_analog_pins();
int8 i2c_command = 66;
while (true)
OKU=0;
i2c_start(); // Start condition
i2c_write(0x12); // Device address
i2c_write(0x00);
i2c_write(4); // Write Command
i2c_stop(); // Stop condition
output_toggle(pin_C0);
i2c_start();
i2c_write(0x00);
i2c_start();
i2c_write(0x13);
OKU=i2c_read(0);
i2c_stop();
if(OKU==4)
output_toggle(pin_A2);
Code: | #include <16F18346.H>
/* Setup I2C */
#use i2c(SLAVE, I2C1, address=0x12, FORCE_HW)
BYTE address, buffer[0x10];
#INT_SSP
void ssp_interupt ()
int8 incoming, state;
state = i2c_isr_state();
if (state <= 0x80) //Master is sending data
incoming = i2c_read();
if(state == 1) //First received byte is address
address = incoming;
if(state == 2) //Second received byte is data
buffer[address] = incoming;
if(buffer[address] == 4)
if(state == 0x80) //Master is requesting data
i2c_write(buffer[address]);
main()
set_analog_pins();
enable_interrupts(INT_SSP);
while (true)
Posted: Wed Jul 07, 2021 2:18 am |
OK. The problem was you referred to a slave address of 13, and this can't happen. The R/W bit is not actually part of the 'address'...
Anyway, going on to your code. The problem is how address==80 is
handled. I again refer you to the example. The point is that when you
do the read on address 0x80, you must do I2c_read(2), not the standard
read. If you do the standard read, it releases the bus, and then the slave
does not have time to load the reply.....
So:
#INT_SSP
if (state==0x80)
incoming = i2c_read(2); //critical - reads without releasing clock
if(state == 1) //First received byte is byte address
address = incoming;
if(state >= 2 && state!=0x80) //Second received byte is data
if(state >= 0x80) //Master is requesting data
I've also changed it so it can handle more than one byte sent or
received. You were only handling state 2, not 3, 4, 5 etc.. |
L.T.
Posted: Wed Jul 07, 2021 2:49 am |
Ttelmah wrote: | OK. The problem was you referred to a slave address of 13, and this can't happen. The R/W bit is not actually part of the 'address'...
Thanks a lot Ttelmah! It works. |
