PIC Workbench Talk
Regular Guy
PIC Workbench Talk
PostPosted: Mon Jul 05, 2021 8:01 pm     Reply with quote
Was looking at 10F200 datasheet.
Saw the FOSC4 pin. Actually 'Function' in pin description.
Says Oscillator/4 Output.
What does the 4 mean?
Is this a good pin to connect oscilloscope to?
I suppose the other lead would go to ground.
Here is the datasheet.
https://ww1.microchip.com/downloads/en/DeviceDoc/40001239F.pdf
PIC Hobbyist
PostPosted: Mon Jul 05, 2021 8:08 pm     Reply with quote
The pin will have 1/4 of the PIC clock speed on it...
say the PIC is running at 4MHz, then the pin will have a 1MHz square wave as seen with an oscilloscope. It could be used as a 'clock source' for external peripherals or say another PIC.
Most PIC I/O pins have several uses, so you'll have to choose IF you want that function.
Regular Guy
PostPosted: Mon Jul 05, 2021 8:16 pm     Reply with quote
Thank you
You beat me to it about pin being multiplexed.
Datasheet pin description also says this.
For that pin 4
TOCK1
Clock input to TMR0
Seems like that would take some work on control register.
Timer0 module. To make it clock in.
PIC Hobbyist
PostPosted: Tue Jul 06, 2021 7:21 am     Reply with quote
You almost never have to touch a register in CCS.
To set that pin to be a clock input, you use the setup_timer_0 function,
with the setting T0_EXT_L_TO_H (or H_TO_L).
This sets it to clock on the high or low edge of the clock applied to this
pin.
