Regular Guy
7 Segment LED Hardware Connections |
Posted: Mon Jun 28, 2021 12:15 pm |
Here it is.
https://www.futurlec.com/Mini_Seven-Segment.shtml
On the back is a 10 pin female connector.
How do we check with ohmmeter for common ground please?
Thanks! _________________ PIC Hobbyist |
Joined: 01 Jul 2010 Posts: 9168 Location: Greensville,Ontario
Posted: Mon Jun 28, 2021 8:28 pm |
not really a CCS compiler question, basic electronics101 but....
honestly contact the seller or the manufacturer of the product THEY should have the information !
sometimes they print the pinout on the PCB, though I only see the front of the module
depending on the connector ,with a 3 volt battery and 2 leads you can 'ring out' (locate...) which pins are the segments .
it's a Toshiba 5161A device, download the datasheet, use DVM-ohms(bzr) to see where the display pins go....
now a clever guy WOULD use a PIC connected to all 10 pins, cut code to test all the possibilites, save the results ,then 'decode' which pins are the segments and the cathode.....
jay |
diode_blade
Joined: 18 Aug 2014 Posts: 53 Location: Sheffield, South Yorkshire
Posted: Tue Jun 29, 2021 5:20 am |
There is usually the manufacturer's part number on the side or top of the display.
Google this and you should be able to download the datasheet, for that 7 seg display, it will have the pin out.
Dave
Edit:
I see Temtronic has already said that. Note to self Read full post first...
![Very Happy](images/smiles/icon_biggrin.gif) |
