Microchip Assembler Sample Code Configuration
Regular Guy
PostPosted: Fri Jun 25, 2021 10:57 am     Reply with quote
The samples have no configuration line written in the code.
Do they want you to set the configuration bits in Configure/Configuration
Bits? From menu bar.
Then you uncheck the box 'Configuration Bits set in Code'?
Thanks!
MPLAB IDE 8.92
PIC Hobbyist
PostPosted: Fri Jun 25, 2021 12:09 pm     Reply with quote
The samples have all the configuration bits written in the code.
In CCS, you don't explicitly set the bits. You set the fuses, and things like
setup the RS232, I2C etc., and the compiler generates the configuration
bits for you. If you load a compiled project, with the load configuration
bits option selected, you will see all the bits are set to sensible values.
Things set stuff up for you.
So
#use delay(internal=32MHz)
Will set all the fuses to setup the internal oscillator to 32MHz (on a chip that
supports this).
#use deflay(crystal=4MHz)
With setup the XT oscillator.
etc. etc..
Regular Guy
PostPosted: Fri Jun 25, 2021 2:05 pm     Reply with quote
https://photos.google.com/photo/AF1QipOEmb2v67dKYE1-PoJPRNaRpzvLraMXJuh_GBAj
Thank you Ttelmah
Here is screenshot.
It is configuration bits for 16F872.
How do we ADD items to the configuration bits please?
PIC Hobbyist
PostPosted: Fri Jun 25, 2021 8:37 pm     Reply with quote
Sign in
to continue to Google Photos
Your link requires a login to view it. People on here don't like logins.
Use an image host that doesn't require logins, such as imgur.com
Regular Guy
PostPosted: Sat Jun 26, 2021 1:01 am     Reply with quote
[img]https://photos.google.com/photo/AF1QipOEmb2v67dKYE1-PoJPRNaRpzvLraMXJuh_GBAj[/img]
Thank you PGM Programmer
See how this one looks.
This is using Image button. Last one was using URL.
How do we add to this please?
PIC Hobbyist
PostPosted: Sat Jun 26, 2021 2:29 am     Reply with quote
It still requires you to login with a Google login to access it. It then doesn't
work. Gives "The requested URL was not found on this server. That’s all we
know.".
As PCM says just use one of the public photo sharing sites.
However on your chip, there are only 12 configuration bits:
Two code protection bits (however only two combinations of these
are supported)
Debug enable
Flash write enable
Date eeprom protection
Low voltage programming
Brownout reset enable
Power up timer
Watchdog enable
Two bits to control the oscillator type.
These are simply set or cleared by the fuse options:
Fuses: LP,XT,HS,RC,WDT,NOWDT,PUT,NOPUT,BROWNOUT,NOBROWNOUT,LVP
NOLVP,CPD,NOCPD,WRT,NOWRT,DEBUG,NODEBUG,PROTECT,NOPROTECT
These give every possible combination of these bits...
Regular Guy
PostPosted: Sat Jun 26, 2021 11:15 am     Reply with quote
Thank you Ttelmah
1 Photos are with Google Photos.
Will see how Google Drive works.
2 We are still thinking about your Configuration Bits info.
Thanks!
PIC Hobbyist
