WalkOver
| dsPIC33EP, can-pic24_dspic33.c driver mask and filter help |
Posted: Fri May 14, 2021 3:02 am |
Hello
I am still a young padawan in C language and I need help with this CCS CAN driver ( and CAN bus in general ).
I have a custom board and the CAN bus works like charm without filter.
I send data and receive data on interruption, no problem.
But now, I would like to implement filter. So I use define before can_init();
but I receive no data on the bus.
I just want to receive message with 0x300 ID for example.
So I config filter 0 to 0x300 and mask 0 to 0x00000000 but it seems it is not the right way to do that.
#define CAN_USE_FILTERS TRUE
#define CAN_USER_FILT_0 0x00000300 // x being the filter to enable (0-15), and aa being the Id to filter for.
#define CAN_USER_FILT_0_TYPE CAN_FILTER_TYPE_EID // x being the filter to setup (0-15), and bb being the filter type:
// CAN_FILTER_TYPE_SID - filter Id is a SID Id, only the SID bit of filter are written the EID bits are set to 0.
// CAN_FILTER_TYPE_EID - filter Id is an EID Id, the SID and EID bits of filter are written.
#define CAN_USER_FILT_0_BUFFER CAN_FILTER_BUFFER_0 // x being the filter to setup (0-15), and cc being the buffer to assign.
// the filter to, see CAN_FILTER_BUFFER for options.
#define CAN_USER_FILT_0_MASK CAN_FILTER_MASK_0 // x being the filter to setup (0-15), and dd being the mask to use with
// the filter, see CAN_FILTER_MASK for options.
#define CAN_USER_MASK_0 0x00000000 // y being the mask to setup (0-2), and ee being the Mask for the filter Id.
#define CAN_USER_MASK_0_ID_TYPE CAN_MASK_ID_TYPE_EID // y being the mask to setup (0-2), and ff being the Mask Id type:
// CAN_MASK_ID_TYPE_SID - mask Id is a SID Id, only the SID bits of Mask are written the EID bits are set to 0.
// CAN_MASK_ID_TYPE_EID - mask Id is an EID Id, the SID and EID bits of Mask are written.
#define CAN_USER_MASK_0_FILTER_TYPE CAN_FILTER_MASK_TYPE_EITHER // y being the mask to setup (0-2), and gg being the filter mask type:
// CAN_FILTER_MASK_TYPE_EITHER - match either SID or EID messages, ignores EXIDE bit of filter.
// CAN_FILTER_MASK_TYPE_SID_OR_EID - only match SID or EID messages, EXIDE bit of filter determines type of messages received.
#include <can-pic24_dsPIC33.c> |
It is possible to have some help or guidance ?
Thank you very much  |
Posted: Fri May 14, 2021 10:59 am |
The key document that needs a lot of reading is 70070D.pdf from
Microchip. This has the filter description given above in paragraph
23.7.2, but also an enormous amount more about how the filters work
DBEN also changes what filters can be used, and how multiple filters
work together. It really is essential reading, but rather big...  |
