SOLVED: #IGNORE_WARNINGS to ignore #include source files?
allenhuffman
PostPosted: Fri Apr 23, 2021 9:44 am     Reply with quote
The Wiznet library has a bunch of warnings in it, and I wanted to quiet them down by doing something like this:
#IGNORE_WARNINGS 203 // Condition always TRUE
#IGNORE_WARNINGS 204 // Condition always FALSE
#IGNORE_WARNINGS 209 // Assignment to enum is not of the correct type
#IGNORE_WARNINGS 214 // Operator precedance rules may not be as intended, use () to clarify
#include "socket.c"
#include "wizchip_conf.c"
#include "wizchip_conf.h"
#include "w5500/w5500.c"
#include "w5500/w5500.h"
#IGNORE_WARNINGS NONE
This does not seem to work. Ideally, we would not want to touch the original source so it can be updated without extra work each time.
Thoughts?
Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ?
PostPosted: Fri Apr 23, 2021 12:26 pm     Reply with quote
hmmm.. does ignorewarnings none defeat the previous commands ?
PostPosted: Fri Apr 23, 2021 1:35 pm     Reply with quote
It works for me. I tried all combinations of the #ignore_warnings
lines below (commented out or not) and it works as desired.
This was with CCS vs. 5.103
#include <18F46K22.h>
#use delay(internal=4M)
#IGNORE_WARNINGS 203  // Disable Condition always True warning
#include "test.h"
test_func();
test.h file:
void test_func()
allenhuffman
PostPosted: Fri Apr 23, 2021 9:13 pm     Reply with quote
You can turn it on and off that way. We always try to have zero warnings, and use this for places we want to ignore. Like this common one:
Switch (x)
   Case 1:
      Function();
      Break;
   Case 2:
   Default:
      DefaultFunction();
      Break;
Sorry about the caps. Typing in the tablet.
CCS will give a "missing break" warning which is a good warning in case someone truly did mean those to be two different case statements, but you work around it by muting the warning just around that bit of code:
#ignore_warnings 204
   Case 2:
   Default:
      DefaultFunction();
      Break;
#ignore_warnings none
...or whatever that specific missing break warning is. We use that often when we have a default case like that.
Maybe the issue is including a .c file rather than a .h and if parses it differently. I’ll experiment next week when I am back in the office.
PostPosted: Sat Apr 24, 2021 5:11 am     Reply with quote
FWIW, when I have empty cases back to back I put a pair of empty braces after each case and then I don't get the warnings.
switch (testit)
        case 1: {};
        case 2: {};
        case 3: {};
        default: testit=testit+1;
allenhuffman
PostPosted: Sat Apr 24, 2021 6:18 am     Reply with quote
switch (testit)
        case 1: {};
        case 2: {};
        case 3: {};
Interesting. That must be a CCS thing, just like while(1) is a warning but using their while(TRUE) is not. Since it definitely is still missing a break.
PostPosted: Sat Apr 24, 2021 7:24 am     Reply with quote
On the break, why not use the nobreak define given by CCS in their
readme, to avoid this?.
allenhuffman
PostPosted: Fri Apr 30, 2021 12:23 pm     Reply with quote
Cross-compatibility with other compilers. At a previous job, two of the compilers (one was GCC) had a way to flag this, but each used a different syntax so it made for non-portable code. #defines were used to do all that.
I'm doing the same for "_readonly" in the CCS code so I can still build it externally. We tend to write out routines in ANSI-C on a PC compiler to get all the logic worked out, then do any necessary updates for PIC (like not being able to pass in a constant string by default).
If this works when #including a .h file, it apparently is turned off when doing it for including a .c :(
allenhuffman
PostPosted: Fri Apr 30, 2021 12:24 pm     Reply with quote
Where is this? I just did a search and did not find a hit for "nobreak" in the help file. It may be easier than #define the IGNORE_WARNING macro.
allenhuffman
PostPosted: Fri Apr 30, 2021 1:11 pm     Reply with quote
#IGNORE_WARNINGS 203,204,209,214,215,237
Solved: All one one line, with commas, not separate.
PostPosted: Fri Apr 30, 2021 1:23 pm     Reply with quote
It's in the latest readme.txt file:
A new warning has been added to the compiler to indicate when a
case inside a switch does not have a break. For those who know
there is no break and don't need the warning you can do something
like this:
#define nobreak
    case 4:  handle_four();
             nobreak;
    case 5:  handle_five();
allenhuffman
PostPosted: Fri Apr 30, 2021 1:29 pm     Reply with quote
I just found that in the PICC program directory. I do not remember if I even realized there was a readme with the updates! Thanks!
PostPosted: Fri Apr 30, 2021 10:18 pm     Reply with quote
Apologies for not seeing that you had asked where this was...
The readme.txt, just occasionally has some absolutely brilliant little bits
like this. Like you, I had hit the case with no break problem, and found
this. I do now make it a 'point' to look in the readme when a change
happens in the compiler. Very Happy
