Digital Capture and PWM Control
jake1272
PostPosted: Mon Apr 05, 2021 1:56 am     Reply with quote
How can I implement a code to input a frequency value via RS232 and set the output to it?
Here is my attempt.
#include <16F1847.h>
#fuses INTRC_IO,NOWDT,NOPROTECT, MCLR, NOLVP
#use delay(clock=8000000)
//#USE PWM(FREQUENCY=25000,DUTY=50,OUTPUT=PIN_B3)         //Configure initial PWM signal
#use RS232(baud=9600, UART1)                           //RS232 on Pin B1 and Pin B2
                                                       //Oscilloscope on CCP pin B3
//float freq,
float TMR2count;
unsigned int16 duty;
void SET_SIGNAL(){
    setup_timer_2(T2_DIV_BY_16,TMR2count,1);   //Setup Timer2 with calculated counr from input frequency from RS232
    setup_ccp1(CCP_PWM);                        //Configure CCP3 for PWM
    duty = 500;
    set_pwm1_duty(duty);
void main(){
float freq;
//delay_ms(200);
while(1){
    printf("\nWhat is your frequency?\n");
    scanf("%f",&freq);
   freq = getc();
    TMR2count=((1/(freq*(4/8000000)*16))-1);
SET_SIGNAL();
PostPosted: Mon Apr 05, 2021 5:18 am     Reply with quote
Some problems I see...
1) TMR2count cannot be a float.
2) 'ERROR' has to be added to the #USE RS232( ...options....)
3) Some form of range checking of the 'desired frequency' needs to be added.
1 and 2 are easy fixes.. #3 depends upon what the datasheet says are valid numbers, based upon clock frequency and timer setups.
4) Not too sure what 'freq=getc' is supposed to do.
jake1272
PostPosted: Mon Apr 05, 2021 5:46 am     Reply with quote
Following your instructions.
Here is my second attempt
#use RS232(baud=9600, UART1,Errors)                           //RS232 on Pin B1 and Pin B2
//float freq,
 void SET_SIGNAL();
float Getfreq;
//int TMR2count;
float TMR;
void main(){
while(1){
    delay_ms(200);
    if (scanf("%f",&Getfreq)){
    printf("\r\nFrequency is: %f",Getfreq);
    TMR =(1.0/(Getfreq*(4.0/8000000.0)*16.0))-1.0;
    if (TMR>255) TMR=255;
    SET_SIGNAL();
SET_SIGNAL();
void SET_SIGNAL(){
   int TMR2count=TMR;
    setup_ccp1(CCP_PWM);                        //Configure CCP1 for PWM
    duty = 500;
