Switching inLVL register in EUSART
Bieli
PostPosted: Wed Mar 24, 2021 4:34 pm     Reply with quote
PIC 16F18456
CCS 5.084
Standard problem 5V PIC and 3.3 UART device. Of course it won't work because PIC input High is >0.8Vdd.
Can I change INLVL register to work as TTL not ST? This would solve this problem (I think). Of course 3.3V device must tolerate 5V input.
I didn't find information how to change INLVL register in CCS. Any suggestion?
Regards
Re: Switching inLVL register in EUSART
PostPosted: Wed Mar 24, 2021 4:47 pm     Reply with quote
In the current version of the compiler, it has the set_input_level_x()
function, where 'x' is the port a, b, c, etc.
The CCS manual says:
Function:
These functions allow the I/O port Input Level Control (INLVLx) registers
to be set. Each bit in the value represents one pin. A 1 sets the
corresponding pin's input level to Schmitt Trigger (ST) level, and a 0 sets
the corresponding pin's input level to TTL level.
If that's not supported in your version, then use this (for example):
Put this line above main():
#byte INLVLA = getenv("SFR:INLVLA")
Then in main(), do this:
INLVLA = 0x01;  // To set pin A0 to be a Schmitt Trigger input
