Interrupts, Timer
jake1272
Interrupts, Timer
PostPosted: Wed Mar 24, 2021 1:33 pm     Reply with quote
The compiler is CCS v5.015
The IDE is MPLAB X IDE v5.40
Hi everyone,
I want to change the code that will sound a buzzer once for a second to begin and then again when the time is up. I have tried it with an LED but with no success. As far I know "longer delays can be produced by using a slower clock or more count variables".
Any help will be appreciated.
Thanks,
Jake
void main(){
n=10;
Count=0;
output_low(PIN_B1);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_8); //Setup timer 1 with a 1/8 prescaler
enable_interrupts(INT_TIMER1);//Enable Timer interrupt
enable_interrupts( GLOBAL);//Enable selected interrupts
while(1){ //Loop forever
  Count++;
  if(n==0){  //Reduce n by 1 and check if n=0
     printf ("Interrupts = %Lu", Count);  //if so, print interrupt message
     output_toggle (PIN_B1);
  n=10;{
            //and do nothing
  }         //Processor is free
PostPosted: Wed Mar 24, 2021 4:24 pm     Reply with quote
Here are two sample programs that might help:
http://www.ccsinfo.com/forum/viewtopic.php?t=58888&start=4
http://www.ccsinfo.com/forum/viewtopic.php?t=53961&start=7
jake1272
PostPosted: Thu Mar 25, 2021 3:52 am     Reply with quote
Thank you. How do I make a loop for the counter when the time
it is up to turn on the led again?
 #include <16F1847.h>
#fuses NOMCLR NOBROWNOUT NOLVP INTRC_IO
#use delay(clock = 4MHz)
 int8 led_seconds_timer = 0;
 #define INTS_PER_SECOND 2
 #define LED_PIN  PIN_B1
#INT_TIMER1
#INT_TIMER1
void t1_isr(void)
static int8 int_count = INTS_PER_SECOND;
int_count--;
if(int_count == 0)  // Has 1 second passed ?
   int_count = INTS_PER_SECOND;  // If so, reload counter
   if(led_seconds_timer)  // Is the LED timer running ?
      led_seconds_timer--;  // If so, decrement it
      if(led_seconds_timer == 0)  // Is it done ?
        output_low(PIN_B1); // If so, turn off the LED
          delay_ms(4000);
else {
    output_high(PIN_B1);
void Timer1_isr(void){
  set_timer1(0);                              // Timer1 preload value
  clear_interrupt(INT_TIMER1);    // Clear Timer1 overflow bit
// This function turns on the LED and sets the
// number of seconds that it will stay on.
void turn_on_led(int8 seconds)
output_high(PIN_B1);  // Turn on the LED
led_seconds_timer = seconds; // Start the LED timer
void main(){
   output_low(PIN_B1);
  setup_oscillator(OSC_4MHZ);                    // Set the internal oscillator to 4MHz
  enable_interrupts(INT_TIMER1);                 // Enable Timer1 interrupt
  enable_interrupts(GLOBAL);                     // Enable global interrupts
  setup_timer_1(T1_INTERNAL | T1_DIV_BY_8);      // Timer1 configuration: internal clock source + 8 prescaler
  turn_on_led(1);
  while(TRUE);                                   // Endless loop
